Does anyone know where to buy HS 33 (banjo fittings) 90* bends?
I bought some from a Australian recumbent builder (over the net) but they only work in the smaller hole on the lever which is actually the bleed hole and don’t have anything to seal the bigger hole where currently the hose connects using an olive. This must have been the arrangement with the older HS 22.
Rolf, are you describing a chain-tensioning part? I can’t tell if it’s something like that, or something deserving of a comment like the one from Carlos.
Also I was curious about your avatar. Is that a picture of Randy Judkins?
