How to remove seat cover...
I used the search function and couldnt find this so if there is a thread for this just link it for me :slight_smile:
if not. i wanna know how to remove a seat cover from an onza saddle. it has the stapples like the koxx one seat.
i wanna change to a KH seat cover without damaging the original cover…is this possible and if so how do i do it?
thanks
  1. Remove seat from post
  2. Remove bumper and/or handle from seat
  3. Using a screwdriver, gently pry the staples from the cover
  4. Slowly and gently, peel the cover away from the seat base
The cover will have been glued to the seat, so there is no avoiding some damage to the base, foam and/or cover… but you can minimize the damage by going slowly and carefully.
If the cover is being stubborn, you may need to use a hobby knife or similar razor blade to remove it. Just be very careful and go very slowly. You want to cut the glue, not the cover!
What he said :slight_smile:
Just take your time
