I recently snapped my pedals so I put my old torker cx pedals on my nimbus cranks. Now that my cranks are stripped I’m curious as to whether these pedals are the wrong size. But I don’t know how to check. any ideas?
edit: I did have them on the right side because only one crank stripped.
There are two main sizes for pedals that I know of, 9/16" which is the main size that unicycles use, and 1/2" (slightly smaller diameter more commonly used in BMX racing I think). You can be pretty sure that your pedals aren’t 1/2" because they would be so loose in the threads that you wouldn’t be able to ride. Pedals unwind when you ride backwards, or ride forwards with the wheel backwards (if you get your frame/seat on the wrong way by mistake) and that can cause them to get stripped if you don’t notice it happening in time to tighten it. Tighten them as soon as you feel them wriggling or wobbling.
Both of those are 9/16". I bet you either put them on backwards (the left pedal will have a “L” and/or the right a “R” somewhere on it), or let them get too loose from riding backwards, idling, or having the wheel on backwards.
I’ve had one pedal loosen to the point that it practically fell off and the other one was still very tight. Luckily I didn’t strip the cranks.
Your crank may not be stripped too badly. Put some new pedals on w/ some Locktite on the striped side (making sure the right IS on the right and you put it back in the frame in the correct direction). If that doesn’t work, take your crank off and take it to your school’s machine shop. Ask the teacher help you drill it out and install a new insert.
By drilling out the hole, threading it and then screwing in a threaded insert. Can’t believe there’s anywhere that will do it for less than the cost of a pair of cheap cranks though.
I realise that the ads at the bottom of the page change regularly, and are based on content, but I thought I’d screen-shot this as I think it’s the most accurate one I’ve ever seen on here.
Cheap cranks won’t have enough metal around the insert to hold IMHO.
It takes an hour to remove the crank, install it in a vise under a drill press to bore out the old threads, twist in the thread tap for the insert, install the insert,and reassemble the uni. It would be a pain to do yourself, and the cost of the insert plus tool wear would be several dollars. Plus $/hr. labor in your town.
IMHO, if you have stripped the threads in a cotterless crank, put a cheap pedal in with plastic metal, ride it easy, and order new cranks.
Much better then a thread insert to fix stripped cranks would be to weld the hole closed, then drill and re tap it.
The labor cost would buy you at least 5 pairs of excellent cranks.
An even easier thing to do would be to just weld the pedal in place. Ok, so you won’t be able to get it out again, but if the crank is hosed anyway, then the cost of a pedal isn’t exactly going to break the bank.
Ummm… too many double negatives for brain to comprehend. Yes, that’s Firefox.
