How to begin unicycling
Some weeks ago, when I decided I wanted to learn how to ride a unicycle, I used
the instructions on
http://www.juggling.org/help/circus-arts/unicycling/starting.html, to get me
started. Now that I am able to stay on allmost for as long as I want and make
turns, I would like to contribute with some of my own experiences.
  1. Choice of unicycle: I chose a 100 dollar cycle with a 24" wheel to start.
    The idea was, that a bigger wheel will have stronger dynamic forces, once it
    gets going. That would make for slower movements and thus make it easier to
    stay on. I think I was right.
  2. Getting on it for the first time, I was surprised how hard the saddle is, as
    all my body-weight was resting on that small saddle. Also the banana shape
    of the saddle hit my soft front-parts somewhat maliciously, when I fell off
    the first couple of times. Do not worry about this. As soon as you get a
    feel for the cycle you stop hurting your soft parts. The first day I spent
    just sitting on the cycle, holding on to a wall, trying to find my
    equilibrium, while watching tv.
  3. Choice of surface: I am an executive and cannot afford a broken limb. Also I
    have allways been the careful type, so my biggest concern was falling off.
    So I chose to start practising on the lawn, instead of on pavement. In my
    experience it is not that much harder to ride on a lawn, allthough the rough
    surface makes you fall off a lot. But then in the beginning, you fall
    anyway, and the lawn is better to fall on. Once you can ride confidently on
    the lawn, the pawement is a piece af cake.
  4. Falling off: I started by holding the uni in front of me, the left pedal
    horizontal pointing towards me. Holding on to the wall, putting the left
    foot on the pedal thus pushing the cycle towards me. Then catching the
    movement with my right leg on the other pedal. Thus I got on. Ten I stood up
    lightly on the pedals, to arrange my soft parts. Holding onto the wall, I
    then leaned forward a bit, and caught the movement by pushing the pedals.
    This got me going. Doing this, I fell off a lot, but learned how to land on
    my feet and grab the cycle. When I really fell, I usually fell forwards, and
    rolled it off. Only twice did I fall backwards, which really hurt. I bought
    arm and knee protectors, like skaters use, for 10 dollars. But that wasn’t
    really necessary.
  5. Then I started cycling forward a little, allways holding on to the wall.
    After a while I could leave the wall and cycle straight onto the lawn for
    a few feet.
  6. I found that it helped to change the starting point, so I didn’t get used to
    allways starting from the same place.
  7. For the next few days, I started next to the wall, and then cycled straight
    onto the lawn, getting further every day. Paddling my arms was vital to keep
    the equilibrium. Usually I kept trying, until I had a fall that hurt. Then I
    stopped, because the pain distracted me.
  8. The next step: I kept cycling over the lawn, until I made it out to the
    pawed road. I was still afraid of falling, so I stopped before I got onto
    the pavement. Then, when I finally got onto the pavement, I found I could
    suddenly keep going allmost infinitely, that is until somebody said
    something, a bug hit me, or something else distracted my attention. Having
    practised on the lawn, the little uneven parts in the pavement didn’t bother
    me at all.
  9. Looking straight ahead: Until now, I had been looking down, something like
    10 feet ahead of me. Only now did I start looking straight ahead.
  10. Turns: To turn, I force the unicycle around with my hips, and paddle harder
    with the outside arm. It is very similar to steering a motorcycle, in that
    you have to lean a little into the corner. Incidentally I still find it
    easier to turn on grass than pavement, maybe because I am less scared of
    falling off.
Re: How to begin unicycling
What ever worked for you is fine.
But some of it is definitely different from my experiences!
> it gets going. That would make for slower movements and thus make it
> easier to stay on. I think I was right.
I learned on a 24" because that was what was available.
When I got a 20" I found I could do tricks I could not learn on the 24" (like
idling) and found it much easier to balance.
When idling, it is an advantage to move a small distance for each rock of
the pedals.
> as all my body-weight was resting on that small saddle. Also the banana
> shape of the saddle hit my soft front-parts somewhat maliciously, when I
> fell off the first couple of times. Do not worry about this. As soon as
> you get a feel for the cycle you stop hurting your soft parts. The first
> day I spent just sitting on the cycle, holding on to a wall, trying to
> find my equilibrium, while watching tv.
Some saddles fit better than others, depending on the shape of your body! The
Schwinn type seat is definitely more comfortable than most.
> I have allways been the careful type, so my biggest concern was falling
> off. So I chose to start practising on the lawn, instead of on pavement.
> In my experience it is not that much harder to ride on a lawn, allthough
> the rough surface makes you fall off a lot. But then in the beginning, you
> fall anyway, and the lawn is better to fall on. Once you can ride
> confidently on the lawn, the pawement is a piece af cake.
I learned in college in the halls of the buildings.
I personally found that learning on a very flat surface made it much easier.
You should learn right at the start how to fall forward onto your feet (or,
backward onto your feet). Then, it does not matter how hard the surface is.
One surface that is very difficult to ride on (for me): Indoor/outdoor
carpeting.
Looking straight ahead helps right from the start.
> harder with the outside arm. It is very similar to steering a motorcycle,
> in that you have to lean a little into the corner. Incidentally I still
> find it easier to turn on grass than pavement, maybe because I am less
> scared of falling off.
Turning is definitely easier on a hard flat surface.
But… whatever works for you!
Best wishes, Robert Bernstein Santa Barbara, CA rdb@silcom.com
http://www.silcom.com/~rdb
> used the instructions on
. . . snip . . .
> keep the equilibrium. Usually I kept trying, until I had a fall that hurt.
> Then I stopped, because the pain distracted me.
. . . snip . . .
I would have to disagree with the last practise method: don’t stop after hurting
yourself or a bad fall, unless it’s reallllly bad. My reason is that this last
psychological defeat will stick in your mind and you’ll be more reluctant to go
out and practise next time. I always try and end a practise session with a
success so that it’s more of a pity to stop than a necessity.
I learnt to roller blade on the weekend, and had a bad fall in which i did the
classic arms flailing skating on air thing. If i’d stopped, I probably wouldn’t
have bladed again for a while, but i kept on going and now want to do it lots
more. In contrast, when i was learning to ride an ultimate, i had a few scary
falls and decided to stop. Becvause of this, i’m always scared when i do
practise, and don’t practise much on it at all.
Nic amateur psychologist :slight_smile:
