How skilled and what unicycle level are you?
Hi just letting you know that im level 4 in unicycling and heading onto 5 although i can demonstrate about 6 types of mounts and can ride backwards for 100m and ride one pedal for 10m. Anway whats your levels? =]:wink:
IUF Achievement Skill Levels
These achievement skill levels have been complied from years of research and surveys among unicyclist from all over the world. They are intended to encourage unicyclists to progress at an even pace over a wide variety of unicycling skills. These levels are not connected to the competition rules, other than in descriptions of how the skills are to be performed. Skill levels are useful for helping riders determine a sequence of skills to learn, and to give them ideas for things to try.
Eligibility:
In order to be eligible to achieve a level a rider must have passed all previous levels.
Riders must get into and out of all skills:
All riding skills start with the rider riding forward, seated with both feet on the pedals except for side ride (level 10). All skills end with rider riding forward at least 3 full revolutions of the wheel, seated with both feet on the pedals.
Maximum of three mistakes per level:
In order to pass an exam a rider must perform all skills in that level at the first attempt, except for a maximum of three skills that must be performed at the second attempt. This allows for three mistakes per level, but no more than one mistake per skill.
Explanation of Skills:
The correct execution of the skills is described in Standard Skill Descriptions, section 7.2 in the IUF Regulations For Internetional Competition.
Variety of Mounts:
At each level starting from level 3, riders must add one new mount to those they have previously demonstrated. Repeating the same mount with the opposite foot does not constitute a different type of mount. A listing of some of the known mounts can be found in the Standard Skill Descriptions, section 7.2 in the IUF Regulations For International Competition.
Recognition of Level Achievement:
To formally achieve a skill level a rider must pass a skill level exam with an authorized examiner. Examiners are authorized by the IUF, the USA or other connected unicycling organizations. If no authorized examiner is available, riders can send a video tape, with no edits per level, to an authorized examiner in their country, or to the IUF Skill Levels and Rules Committee. Videos must clearly show all the necessary details of each skill.
Level 1
mount unicycle unassisted
ride 50 meters
dismount gracefully with unicycle in front
Level 2
mount with left foot
mount with right foot
ride 10 meters between two parallel lines 30 cm apart
ride a figure eight with circle diameters smaller than 3 meters
ride down a 15 cm vertical drop
make a 90 degree turn to the left inside a 1 meter circle
make a 90 degree turn to the right inside a 1 meter circle
Level 3
demonstrate 3 types of mounts
ride a figure eight with circle diameters smaller than 1.5 meters
come to a stop, pedal half a revolution backward and continue forward
ride with the stomach on the seat for 10 meters
make a 180 degree turn to the left within a 1 meter circle
make a 180 degree turn to the right within a 1 meter circle
hop 5 times
ride or hop over a 10 x 10 cm. obstacle
Level 4
demonstrate 4 types of mounts
ride backward for 10 meters
ride one footed for 10 meters
idle with left foot down 25 times
idle with right foot down 25 times
ride with seat out in front for 10 meters
ride with the seat out in back for 10 meters
make a 360 degree turn to the left inside a 1 meter circle
make a 360 degree turn to the right inside a 1 meter circle
Level 5
demonstrate 5 types of mounts
ride backward in a circle
ride one footed in a figure eight
idle one footed with the left foot 25 times
idle one footed with the right foot 25 times
ride with seat out in front in a circle
ride with the seat out in back in a circle
ride with the seat on the side in a circle
hop-twist 90 degrees to the left
hop-twist 90 degrees to the right
walk the wheel for 10 meters
Level 6
demonstrate 6 types of mounts
ride backward in a figure eight
ride with the seat out in front in a figure eight
ride with the seat out in back in a figure eight
ride backward with the seat out in front for 10 meters
hop standing on wheel 5 times
ride with the seat on the side in a circle to the left
ride with the seat on the side in a circle to the right
ride one footed with the left foot for 10 meters
ride one footed with the right foot for 10 meters
backspin
frontspin
spin
Level 7
demonstrate 7 types of mounts
ride backward with the seat out in front in a circle
ride one footed with the left foot in a circle
ride one footed with the right foot in a circle
walk the wheel in a circle
walk the wheel one footed for 10 meters
hop-twist 180 degrees to the left
hop-twist 180 degrees to the right
ride backward with the seat out in back for 10 meters
spin to the left
spin to the right
Level 8
demonstrate 8 types of mounts
ride one footed with the left foot in a figure eight
ride one footed with the right foot in a figure eight
walk the wheel in a figure eight
walk the wheel one footed in a circle
ride backward one footed for 10 meters
glide for 10 meters
hand wheel walk for 10 meters
pirouette
backward spin
Level 9
demonstrate 9 types of mounts
walk the wheel one footed in a figure eight
ride backward one footed in a circle
ride backward with the seat out in front in a figure eight
ride backward with the seat out in back in a circle
walk the wheel one footed with the left foot for 10 meters
walk the wheel one footed with the right foot for 10 meters
walk the wheel backward for 10 meters
drag seat in front for 10 meters
drag seat in back for 10 meters
ride backward one footed with the left foot for 10 meters
ride backward one footed with the right foot for 10 meters
one footed with the seat out in front for 10 meters
backward pirouette
Level 10
demonstrate 10 types of mounts
ride backward with the seat out in back in a figure eight
ride backward one footed in a figure eight
walk the wheel one footed with the left foot in a circle
walk the wheel one footed with the right foot in a circle
walk the wheel backward in a circle
180 uni spin
sideways wheel walk for 10 meters
coast for 10 meters
side ride for 10 meters
walk the wheel one footed backward for 10 meters
