how do i turn links into underlined words?
i cant make a new thread untill i find out.
Why can’t you make a new thread till you find out?
But links are usually underlined. The code for a link is
<a href=“URLhere.com”>Text you want clickable</a>. The code for underlining is
<u>underlined</u>.
So if you want to make a link that is underlined, then the code would be
<a href=“URLhere.com”><u>Text you want clickable</u></a>.
Or you can click on the little “http://” button above where you type stuff and follow the directions.
Andrew
because its about time i learned and i wanted to be tricky in my next post.
A_C thanx i had no idea it was there and so easy!
J_P is there any advantage to using your longer method? does it work everywhere?like E-mails and such.
No worries. I also only recently found that button…it’s pretty handy.
It’s dam handy. I only found out when I first registed with unicyclist.com and it’s very handy alright.
David.
