hopping stuff
any tips for hopping down stuff like stairs. i want to try a 3 step had a chance but it didn’t happen. my virticle hop is around 8in.
don’t hop like your on a pogo stick, instead stop for as long as you can between each hop, balancing with your body. if you want to jump in a particular direction let yourself start to fall in that direction and then jump taking the unicycle with you.
kris holm explains it much better at http://www.muniac.com
also watch the videos of the trials workshop at http://lutkus.com/video/Kris_Holm_workshop/
Hopping down stairs I found quite scary… because it’s lower you land faster and there’s not much space to wobble on a step.
Start by doing it slowly… as Ewan says, don’t pogo, try to keep it under control, going one step at a time until you get nearer the bottom. Then you can go for it if you’re impatient… :slight_smile:
Good luck…
Phil
Hey Phil.
Have you posted your video yet?
Its cool!
PUT IT IN YOUR GALLERY… NOW!
hehehehehe,
Joe,
