I have found 3 keys i have both rings and the rod in the box i have a cd case a paper the cassett tapes and the wires what else do i have to do???
Unless you locate the fourth key you will dwell for all eternity in the Slough of Despond.
Bury the other items next to running water on a full moon, while chanting, “Uni, uni, uni” and waving a toad over your head.
After that, you’re on your own…
lmoa! never seen a thread like this one:p
Yeah, that was my first response; but then I thought I should at least try to get into the spirit of the thing…
Once you put the rings and the rod in the box, open it and put the cassette in then you need to get the other battery. the battery is under the foot of the bed ( you need to click in the bottom left corner of the screen with the wall) Put the other battery in the box and watch the guy dance on the wall. when the guy is dancing he will point to a space on the wall. put your mouse there but dont click until he is done dancing. when he is done click three times then a square will appear. click on the square and there will be a safe. in the dial on the safe, type in 1994 and put your other key in. it will open and you will get a screwdriver. click on the doorknob and use the screwdriver. the doornob will fall off and the door will open.
Yeah, I knew that.
ohhhh
i should of known! its that crimson room , or whatever its called. DANGIT i KNEW that! wahtever
where do i find the ROD?
I’ve beaten all the rooms. PM me for tips (I don’t like spoiling things publicly).
PS The room puzzle games are pretty cool, http://www.fasco-csc.com/index_e.html if you don’t know what this is about.
Re: where do i find the ROD?
Lift up the pillow on the bed and click inbetween the matress and the headboard
wheres the other ring?
It falls from the curtain.
I love the room games. There’s another one on albinoblacksheep.com that’s not a room game, but it’s just like it, and like a billion times better.
Re: help
> do???
> pinoplepa16
> pinoplepa16’s Profile: http://www.unicyclist.com/profile/8001
> View this thread: http://www.unicyclist.com/thread/35266Put the lime in the coconut and shake it all up.
cheechee
Why the frick is this in Rec.Sport.Unicycling?
where do you find the second ring?
