and i dont know how much air does my uni tyre should have, and if a want to do biger hops like 1 meter or so, should i get a better unicicle, or just changing my uni rim for a double wall alluminium would do it???
4-5 stairs as a noob?! Man, I need to step up my “A” game! I’m a noob too so I can’t really give any advice…however I haven’t heard very good things about the life span of Sun uni’s. As for air pressure, there is no real specific air pressure for uni tires because it all depends on what you’re looking to accomplish and how much you weigh. If you’re at risk of a pinch flat, you’ll need more air, but not so much that your tire is rock hard and has no bounce…especially for trials. But then again someone will probably say that they like to ride a rock hard tire. It’s ALL pretty relative.
If you are bottoming out and your rim is touching the ground, you should put more air in the tire. Generally its a good idea to add more air each time you bottom out. If you want to do drops that big you may want to look into getting a trials unicycle. Unicycles like the flat top aren’t really designed for big drops, and even if you upgraded the rim, the hub and cranks could still break.
You could get something from unicycle.com shipped to you through one of your American friends on the unicyclist forums
I would do it but I have no idea what it would have to go through for international shipping (if there’s customs, etc.).
Does Amazon.com ship to Columbia? There are some good trials unis on there.
edit: Looks like Walmart actually has a pretty good selection of unis. Still, I would check out Amazon and other shopping sites.
Not that anyone cares but I just sold another one of my friends on K1 as their first uni. This guy is actually getting a Black Domina…can’t wait to see what it looks like.
It really depends on what you think is best. My friend got his K1 Black Domina and I’ve gotta say, I’m pretty impressed with it. We had to file a little bit down on the bottom of the seat tube, but is’s a great uni for under $200. With that said, I’m still very satisfied with the Nimbus my wife bought me off of Unicycle.com. I’d say check out all the suggested “good” uni companies and their unis and just go from there.
I’d say to put in close to the max air pressure in your tire, but if not, get a different unicycle. I own a Sun Flat Top Deluxe too, but it’s a different version. Mine used to be perfect, but it can’t handle all of the stresses I’ve put into it from jumping up stairs and curbs. My hub twisted a while ago, and it just isn’t strong enough. Here’s what my unicycle is: http://www.sunbicycles.com/product_detail.php?short_code=Flat+Top+Deluxe&cl1=UNICYCLES
that one i think is a good unicycle, but sun does not put isis in its unis, i like the k1, one of my biggest problems is the frame, if you compare yours with mine, mi fork has a horizontal tube gong out, yours goes vertically, a huge improvement, because i always hit mi legs with that freaking tube
This thread, “Help” doesn’t read like an article or a tutorial. This is not the proper forum for asking questions.
If you have questions, first search the Unicyclist.com forums (especially Rec.Sport.Unicycling) to find your answer. Being over a decade old, it is more than likely your answers are already here; in this case there is no reason to start a new thread.
If you can’t find your answer (please try at least once for your own benefit), only then should you post your question in Rec.Sport.Unicycling. Not only does it help keep the forums organized, posting in RSU exposes your question to a much wider audience, giving you a chance at a better, more accurate answer.
