The seat on my unicycle has started to turn a lot (whenever i get on, whenever I am doing turns, etc.) and it makes riding very hard.
Does anyone know what I can do to fix this?
I’ve tried tightening the seat post but to no avail.
Still no luck.
Tighten the clamp as tight as you can.
I had the same problem on my 24" DX, but not as bad. I had to hit the lever real hard w/ the palm of my hand several times while wearing my wrist brace (it hurt my palm too much w/o the brace when I had it that tight).
If that doesn’t work, put some deep scratches in the post w/ the pointy edge of a square or triangular file, making it look kind of like it was knurled. This will make bits of raised metal, making your post act like it’s slightly larger in diameter when clamping it.
You probably have the quick release clamp, you can tighten those by first loosening the little lever, then holding it to keep it from turning and tighten the round part on the other side. Then push the lever back down again, and it should be tighter this time.
