>>HELP!! sizing questions
ok i wanna buy a uni that has 71mm center-flange to center flange distance and a flange diameter of 66mm. Will i be able to switch out the hub with a hub that is 75mm center-flange to center-flange and a flange diameter of 65.5mm???
(without getting new spokes)
anyone???
Most likely it will work, if the spokes are sticking out of the nipples then you might want to grind them down.
dude, omg… 1/2mm is absolutely nothing
of course
its probably the same hub
EDIT:sorry if that seems rude
but the flange spacing makes a difference as well. will i run out of threading on the spokes?
i doubt it… if not … what size rim are you lacing?
as long as its not a wacko size (or 19") you shouldn’t have a problem going to your LBS and getting some new spokes
a trials rim, i would probably get spokes online. they arent real cheap at the LBS. im a sucker for good deals
hmm
5mm to the side … .5 mm shorter
~7.5"spokes
make a trianglefrom the center of the hub to the axle area… then to the rim, don’t worry about the flange distance, it is probably exactly the same and figure out the difference in hypotenuses
theres if its smaller than .15 or so inches you should be fine
wow cool i love math and science that was the perfect answer
lol
nice sarcasm
i dont’ want to do it
im not doing it for you
lol
im being lazy ok!
hah
