Basically, need a new uni. I ride street, so need something light but strong. Advice welcome from those who have any,
Thanks,
Jas
Thanks,
Jas
well you’ll need a splined hub and crankset obviously…i recomend the 2005 KH/onza or profiles if you have the money. basically you want the same setup as a trials uni. also i recomend using a luna for street or getting a diferent tire and cutting the knobs off and smoothing the tire for street.
Maybe get a Koxx devil. The only real difference between trials and street is the pedals.
not really with trials the tire is fatter and it is really more then u need…lol or maybe im thinking of something else…
And choose the one with the coolest colour!
mike a street tire is 2.5 …the same a strials …maybe you’re thunking of something else!
First off, would you want a 2.5 trials tire or not? If so, I suggest looking around at unicycle.com, splined is the strongest by far, both the Torker DX and the Qu-Ax trials are strong for a fair price.
If you don’t think you’ll need a knobby wide trials tire, you’ll have to put together a splined uni with a normal 20" rim (trials rims are “19 inches”) and a slick BMX street tire.
Or just buy an older Torker DX. It has the same cranks and hub as the new one, but it has a 2.125"(?) tire instead of a 2.5 inch tire. They are probably a bit harder to find, but they weigh less and are cheap. They have pretty cheasy rims, though.
