HELP! People who are good at solvents..
I spilled a whole cup of fountain pepsi onto one of these
Already wiped the whole thing down yesterday with normal non-name all purpose cleaner. Today some of the keys stick a bit. Please, how can I fix this…keep in mind I cannot open the phone up or unplug it.
Hurry before my boss sees!
…own up to your mistake?
…better late than never.
We’ll your right. I should have said that I plan to tell her, but she won’t be around for a few days so in the mean time I want to get the keys unstuck to lessen the shock for her when she returns.
This is going to sound odd, but I am at work and have oxy acne pads handy. I’ll try that.
cleaning electronics with rubbing alcohol is best because of its fast evaporation rate.
alright cool, thanks all. I’ll giver a try.
of course the stickiness that coke leaves behind will dissolve in water, assuming your technical skills are up to scratch the safest thing would be to strip it apart until there are no electronic components on the front panel and then use water. Failing that, an alcohol is pretty good as it will indeed evaporate fast. Just check on the underside first, some alcohols will readily dissolve some plastics.
