HELP! Pedal insert coming loose
The pedal insert of my right k1 reinforced crank is coming loose, to the point where if i remove the pedal the thread wants to come too! :angry:
Just use red locktite. If there is a retaining ring you can tighten it back on with some slim needle nose pliers.
If the axle is stuck to the crank insert, try tightening it and then undo the pedal.
hope it works!
