Help on seat to the side...
I have been working on seat to the side off and on for about a month so i can pass level five…it is the only thing holding me back…and suggestions?:stuck_out_tongue:
yea raise up your seat sooo stinking high, other wise youll just hit your foot on the wheel forever and get some big burns.
Hi,
I have the same problem for the moment.
I don’t wanna be a “Level-5-Guy” anymore… :smiley:
Can you idle with seat to the side?
That’s really easy and tooks less than 10minutes to learn.
Next Step you can start from a wall and try to ride a small circle.
If you go a little bit down into squat(hope that’s the right word) it will help you to don’t touch the tire while steping the innercircle-pedal.
Which size have the crank you are using?
With a Trial-Uni it’s impossible I think.
With 125mm Cranks you will touch the ground when your innercircle-pedal is down.
I tried 114mm Cranks last weekend and ist was possible to ride a halfcircle after 5minutes.
If your foot touches the ground try to ignore it… :wink:
To ride with seat to the side looks really silly, but learn it and forgot about level5…
Hope it helps you a bit.
Good Luck for practising!
Uli
p.s… Sorry for my english!
^woo thats for clearing that up i have been trying for a year to get seat on side on my trials/muni now i know its pretty much impossible
Yeah i can idle with it on the side…ive been able to do that for a long time…
i dont really know the exact size of my crank but i do know it is a short crank, not a regular size…
