hello forum sun 24'' moding?
lol well i just joined like 12 minz ago so just wanted to drop inn and say hi:D
kk so i have a sun 24’’ idk the model but i was wondering if it was possible to put a fatter 20’’ rim on it … id most likely swap the hub and cranks out aswell
but whats your guys opinion will the geomitry be to far askew or do you think it will work well? :thinking:
It is not a bike so it is not going to have bike like geometry issues when you swap out the wheel. everything is in a strait line.
What do you want the fat tire for? If it is to help jumping with the unicycle you should probably look at getting a trials wheelset. They are 19x2.5" (often listed as 20x2.5) wheels which give you the same outside diameter as a regular 20x2.0 wheel.
I am not sure if the the sun frame is wide enough to fit a trails wheelset but if it is you could give it a try.
Personally thought if you are going to be doing upgrades to a unicycle it might make more sense to start with something more middle of the line like a Nimbus or Torker and go from there.
There is a good chance that the frame might brake if you abuse it too much riding it like a trails. Sun unicycles were never designed for that kind of riding.
thnx for the advice
:frowning: id most likely just get a 19 inch wheel set like you said … im not doing any crazy drops or anything too stressing on it … i just have always liked the feel of a 20’’:slight_smile:
