For me, I really dont need them on the long section of the cranks, but I need it on the nub/axle end of the cranks.
I ride moment cranks, and its thin in that area, so slipping happens quite a bit for me there, so that will be a good spot for the tape. The rest of the crank is somewhat flared, and I dont have a problem standing on it.
Well if you grind put it on most (both sides) of the crank you do not grind on, make sure to wrap it around the axle. on the grinding side only put it on the half that faces up.
As for puttin it on, I get my crank and get an draw outline on a piece of paper and then use that as an outline for the back of the griptape.
Thanks guys. Yea, stuff like this… articles, interviews, reviews and things are the main focus. There should be some other interesting things coming up a bit more often…however making sure all the new vids get posted will always be the easiest content to throw on there. Ideally sponsors will take notice and help with some of the funding issues…;);).
By the way… if any of you have opinions or other comments about griptape on cranks… feel free to leave your thoughts in the comment section bellow the article.
