Grind Plates? Any good tutorials out there?
Just like the title says. I don’t think it’s good to grind on the giant snafu pins, and since I’ve gotten into stuff that uses grinding recently, I’m thinking I’d like to make some plates.
Like this?
http://www.freewebs.com/andrewcarter/streettips.htm#grindplates
I grind with Snafu’s, just take the pins out on one side and make it your grinding side. I painted the word “Snafu” white on the pinned side so I wouldn’t have to check for the pins.
David
I followed that set of instructions and it worked well. After a few weks, though, I removed my grindplate because I didn’t use it (because I can’t grind and I am not currently practising it). After the summer, though, I will make another one.
Danscomp.com>Bike Parts>Pedals>kommando Pedal Grind Plate
a link for that previous post, to save navigating through site
jim
Thanks.
Heeeyy, those are cool, $9.99 I wonder if they would fit a different variety of pedals?
It says they fit most platform pedals but i have gone through 3-4 different kinds before i found some that actually worked. They dont fit the Oddessey twisteds, Welgos, Jimmy C.s and I am pretty sure they dont fit the Primo Tenderizers but i havent used those. Right now I am using snafus with the kommando grindplates and and they work great.
the kommando grind plate fits primo tenderizers, but not primo balance
When your sig is 28 times as long at your post, you have a problem that needs fixing.
