Last night I had a dream that I was gliding!!! Not only was I gliding, but I was also gliding OFF ROAD without going down a hill! This is the official gallery of gliding and coasting dreams!
Re: Gliding and Coasting Dream Gallery
dude… there’s already a gallery of unicycling dreams. Why do we need one just for a specific trick?
I used to dream all the time about coasting. Sometimes I would coast downhill, somtimes even uphill. I recall dreaming about coasting up and down the aisles in an empty hardware store, making sharp turns at each aisle. I have dreamed about doing an effortless stand-up coast, without worrying at all about balancing. Now that I can actually coast however, I haven’t had nearly as many dreams about it.
People always say I’m too harsh, but I really don’t think this is being harsh. The only way this kid is going to learn is through a lot of pointing and a lot of blaming. Or we could just ask him not to make threads like this.
So Mr. Cox, sir.
Please follow this guideline:
(Apply common sense for all topics)
1. Are you posting in the correct forum?
In this case it was true, however I won’t link to any other examples of yours that I could easily find. Well, unless I can be bothered finding the links. Even then I probably won’t bother.
2. Is there already a thread like the one you’re making?
True again, there was one already like this:
Gallery of unicycling dreams…
Move on to the sub sections of topic 2.
2.a. Does you’re post fit in that thread?
True, Mr. Cox. It would have gone perfectly in that thread, it’s a dream about unicycling. Hooray! You can reply to this thread!!!
2.b. Even though there is a thread similar to the one I want to make, would it still be better to start a new thread?
False. There was no need for this. Sometimes it can be better to do this, you see. Say you’re releasing a freestyle video, and someone has a thread entitled New Freestyle Video, then you could create you’re own thread. This section requires the most thought, but you shouldn’t need to have even gone to this section if the answer to 2.a. was true, which it was.
If section 1 is false then you’ve got big problems and should back away instantly.
If section 2 (excluding the sub-sections) is false then you can post your new topic.
Follow that guideline, and you will most likely make more helpful submissions that are easier to find when someone looks for it, and you will make the unicycling community happier! Hooray!
