I know there have been a couple of threads about this. None which helped. Since my 20" is out of commisson for awhile i thought that i would try some giraffe tricks. Its a cheap one so i an’t going to hop on it. I can go backwards pretty good, idle and 1 foot idle. Any other suggestions?
Also i am thinking about performing for a festival that is held in our town. I believe it is like May 28. I was wanting to perform and try to raise a little extra money. Should i charge for them to try it? Should i let them try? What should i do? It would be from like 8 to 7 pm but i probably wouldn;'t perform that whole time. DUH. Any suggestions??
Hopping shouldn’t hurt it, I have a sun or a savage giraffe and hop on it. For tricks you could try seat out riding and see how far you can get it from your body, 1 foot ride if you can, or 1 foot idle and stick you free foot as far out as you can to make it look cooler. You could try a unispin if your really brave.
How about getting some pegs and riding it with your hands? Shouldn’t be too hard.
Also try spins and backward one-footed riding, crank idle, and just about any other non-wheel walking skill except seat drag. Skills as advanced as pirouettes and side ride have been done on giraffes.
I wonder if seat drago would be possible on a giraffe… I bet it would, except for getting into and out of it would be almost impossible. maybe if you had pegs on it, then you could ride with your hands, then drop the seat and frame on to the ground, jump on to the pedals, and ride… then do that backwards to get back up. hrmm.
The best way to seat drag on a giraffe would be to put pegs on it, ride with your hands, coast slowly, set the frame down, lean over, and hand wheel walk it, or just continue to coast (like a BC wheel with a HUGE encumberance). You would need short cranks, otherwise they would hit the ground. I don’t think it would be possible to pedal it, since the seat would break immediately, and also probably the frame.
“James_Potter” <James_Potter@NoEmail.Message.Poster.at.Unicyclist.com> wrote
in message news:James_Potter.1o136k@NoEmail.Message.Poster.at.Unicyclist.com…
Certainly conventional seat dragging would be dificult, because the seat
would be generating a lot of friction, as it would be bearing a substantial
part of your weight. You would need something to make it slippery, or some
mini wheels to allow it to roll without damage. Otherwise, try it only on
a smooth floor .
Well i can ride it one footed now. Still learning though. Also, I can now do the rolling mount onto it. I learned that in just a couple of days. Thanks for all the suggestions.
