Giraffe mount - how it's done
I really appreciate reading through this forum when I got my giraffe, and found some really useful suggestions.
Now that I have succeeded, I want to add something back to the forum, and here it is:
You don’t need to be able to ride well …
You don’t need to be able to ride a giraffe well to freemount it
I have had my giraffe for around 3 weeks, and have the “climb” freemount completely down pat (10 out of 10 tries). I got this freemount right before I could idle on the giraffe (and although I can ride a normal uni backwards, I can’t yet ride the giraffe backwards).
I do believe you’ll need to be confident at idling on a normal uni, before being able to use the climb method for the first time on a giraffe. But you certainly don’t have to be able to ride backwards on the giraffe, or even idle on the giraffe.
A detailed description of the method
Here’s the method I use for the freemount, in some detail:
(1) Giraffe upright, facing forward (no twist, or lean)
(2) Right hand completely down
(3) Left hand pedal made level (to receive left foot).
(3) Right hand gripping front of the seat, in the way that you want it to be once you are up and riding (ie over the top of the seat)
(4) Left hand coming from left hand side, on the middle of the seat (this will stop giraffe twisting on the way up).
(5) Left foot heel approximately the diameter of the wheel behind the wheel.
(6) Left foot facing out left (ie not the direction of the wheel) … there is a good reason for this … it naturally stops your left leg pushing up too much (which will just launch you over the Uni, and lead to another non-landed-attempt).
(7) Look up
(8) You will be concentrating on keeping the uni completely upright while you steadily rise up to the right level.
… NOW (you need to do the next stuff all in a single fluid (but not fast) movement …
(9) Leaving your left foot where it is, move your whole body closer to the Uni
(10) Put pressure on your right foot, and use your right foot to stand up … DO NOT JUMP WITH YOUR LEFT FOOT … THIS IS CRITICAL
(11) When you are standing up, your right hand will move the seat under your goolies (or family jewels) and at the same time your left foot will hit the pedal
(12) You are now on the seat, and the wheel needs to come backwards a little to get your balance right.
(13) You will pedal backwards about a quarter rev, and off you go.
Problems I’ve encountered
[] not getting up high enough … try try again (for me, over 150 attempts in a row)
[] going too far over the top … try try again (and remember - keep the Giraffe upright on the way up … so that your hand puts the seat under the important bits)
[] going too far off to one side … try try again (your left foot placement is important … read above about the heel placement).
How long did it take ?
Day 1 - just jumping up and down and getting nowhere near it
Day 2 - 160 attempts, 5 successes (pure luck)
Day 3 - 160 attempts, 25 successes (pure luck)
Day 4 - 150 attempts, 15 successes (oh #@$%^& !!!) :thinking:
Day 5 - 100+ attempts, 5 successes (!!!)
Day 6 - 25 attempts, 10 successes
Day 7 - 15 attempts 10 successes
Day 8 - 8 attempts 5 successes
Day 9 - 5 attempts 5 successes
… now it is pretty much every time, unless I’m not concentrating, or one of my kids gets in the way (I’m 38 … my youngest is 3 and doesn’t understand how it’ll hurt if I land on him).
Regards from sunny (and dry) Brisbane, Australia.
:slight_smile: :slight_smile: :slight_smile:
I’m glad you added that last bit. I live in Brisbane too. We’ll have to get together for a ride some time. There are lots of keen unicyclists here in Brisbane. Are you at all interested in muni? We regularly go on muni rides on Mt Cootha.
Do you know about unicycles.com.au? The shop is based in Brisbane and run by Gary who co-owns Gap Cycles. The website (www.unicycles.com.au) is horribly outdated. A great new site will be up and running in the next week or two hopefully. Basically there’s a lot more on offer than the site says and it’s all generally cheaper than it says.
See my signature for my email address. My mobile number is 0423 516 982. We should definately get together for a ride. Also check out www.unicycle.2ya.com (Peter van B’s and my site).
Andrew
Actually, do you mind if we grab those tips for giraffe mounting for our Tips and Tutorials site? We already have a video tutorial on giraffe mounting but it’s pretty basic.
Andrew
How tall is your giraffe?
John - mine is a (measly) 5 footer. I am aiming higher, but this size lets me ride around my house (ducking to get through the carport - heh heh).
Andrew - I studied your video when I had the run of bad luck getting started. I loaded it up into Movie Maker, and went frame by frame to see what you were doing that I wasn’t. The bit that really helped, was when I realised that you were pushing in toward the giraffe and holding it almost perfectly vertical when you stepped up. This was the key for me. The key was: don’t try and jump on the seat … the object is to get safely into the saddle in balance, not out of it.
I am very keen to ride more. I need a Muni. I bought the giraffe from the Gap store, after seeing it on your website (hooray !). I’d never seen a giraffe for sale before.
I am very pleased for you to copy the tips and tutorials (thanks for asking). I am very pleased for anyone else to make any use of them … I am stoked that I can do it now … after so many dodgy initial attempts.
I am also very keen to get together for a ride (I’ll contact you during work hours, or you can ring me 3210 0914). My limitation is that weekends are pretty full with kid time. My oldest (who is 7) is learning to ride “no hands” … and wants me to buy him a mini uni for his next birthday. On the other hand, he also likes mountain b*king (you know - with the spare wheel). He’d think it was a hoot to come and watch me UPD (repeatedly).
Speak to you soon, regards (Michael Hains)
Is it much different gettin on a 6 footer than a five foot giraffe. I have a 6 foot - and still unable to freemount. Though i havent practiced a ton - i was discouraged pretty easily i spose.
