Two more pics of MUni and Cokering in the high country. I will send one at a time.
Great pictures, Mike. Where were they taken?
Re: Getting High in Colorado II
phew! did not know you could climb such steep trails with a Coker!
(170mm cranks ?)
would a geared Coker (essentially with reduction …) be possible?
(for instance ratios from 1/3 to 1,20)
bear
Re: Re: Getting High in Colorado II
I’m sure it could be done, but what’s the point? Consider a 24", 26", or 28/29" wheel. It’s lighter, and you have a choice of more than one tire!
On Wed, 29 Oct 2003 10:29:18 -0600, gbarnes
Sometimes, and also in this case, an attached picture’s filename
contains useful info. Right-click the pic and chose Save As to see the
filename, you don’t have to actually save it.
first pic: mike muni rim trail.jpg
second pic: mike top of independance pass 12,095 fall 03’.jpg
Klaas Bil - Newsgroup Addict
Grizzly bear droppings have bells in them and smell like pepper spray. - UniBrier
The MUni picture is from a 15 mile single track combo in Snowmass Village, three ski areas away from Aspen. The part I am on is the RIM TRAIL section.
The Coker picture is from the top of Independence Pass, a 4000’ vertical climb that starts in Aspen.
October was so warm that I was able to ride with very little clothing on both rides.
Most mountain passes are around 7% grade, but I’ve been on some that are up to 20%, thats steep but rideable.
I only use 175 cranks for Uniing around here, both Coker and MUni, there just arent many flat sections in the Rocky Mountains.
Re: Re: Re: Getting High in Colorado II
ok my post was not clear enough.
how do you climb steep slopes with a Coker?
apparently aspen mike does it! but really I do not think I can.
I would love to have a “trail” uni to go along (long) firetrails in the mountains
(that is: do not need a machine that “climbs to tree” like a full blown muni,
but something able to gobble kilometers )
so does a Uni with “reduced” gears make sense to climb long slopes?
(be it a 29er or a Coker)
thanks
bear
What he meant was using gears that could be changed while driving: (for instance ratios from 1/3 to 1,20). These have been made. It would be cool to have a Coker with gears so you could really speed up with something like that 1,20 and go uphills with 2/3. 1/3 might be too small ratio. Maybe should ask Greg Harper and Unifrank about their unicycles. You can also try searching for gears in unicycles.
edit. And remember brakes. I think those hubs with gears can’t be used backwards, so you would be coasting downhills at really high speeds.
On Thu, 30 Oct 2003 07:23:22 -0600, joona
I didn’t read it like that.
Do you have more info? I’ve heard some ideas about them but wasn’t
aware that shift-on-the-fly geared unis have actually been made.
What about the shift on the stop hubs, can you install one on a 36" wheel. It would be crazy to ride a Coker with a 54" gear. Thanks.
