RE: Getting height in rolling hops
Hi Chris,
“You’re off to a good start” - that’s good to hear. “That’s exactly what I felt
like four months ago” - even better!
I’ve got a copy of Universe but no VCR to play it on. However, the times when I
have watched it, I noticed the contortions folk were getting into (doubling up
as they jump) to get serious height. The way I’ve been going so far it’s felt
like I’ve never had any time to bend forward before I hit the ground again.
I was out yesterday and trying out pushing down before take off and noticed a
marked improvement. Pushing down on the pedals also seemed to decrease the need
for a quick standstill. I wasn’t pushing down particularly hard though so I’ll
try that next time. You’re bit about pushing down on the pedals and pulling on
the seat being independent actions makes a lot of sense but isn’t something I’d
been making a conscious effort to think about while practising. I’d guess that
the occasional massive (speaking relatively mind you) jumps I was getting
yesterday probably came as a result of getting the timing just right.
I’m real bad at just learning to do things with my favourite foot and not
learning with the other. Jumping is a must have skill for both feet so it’s time
to regress a bit before making real progress… ho hum
When you say “any
position” do you mean any rather than with either foot forward and the pedals
horizontal?
Would I be close if I said that tyre pressure will aid / impede jumping? As in -
a rock hard tyre will impede jumping as the downward pressure on the pedals
won’t create any real counteraction when the pressure is released. An under
inflated tyre will do the same. So something in between is best - a bit of give
but with enough resistance to react to being squashed?
So many question I know…
Cheers, Neil
-----Original Message----- From: reed8990@uidaho.edu
[mailto:reed8990@uidaho.edu] Sent: 17 November 2000 02:30 To:
n.dunlop@kildrummy.co.uk
Cc: unicycling@winternet.com Subject: Re: Getting height in rolling hops
Importance: Low
Neil Dunlop wrote:
>> Hi All,
>> I’m wondering exactly how to get any decent height / distance to forward
>> rolling hops while riding and with bum on seat.
>> At the moment I’m riding along and coming to a very brief standstill. I
>let
>> my body weight carry forwards slightly then launch using my ankles and
>> pulling on the seat. At a guess I’m getting what feels like 6" in both
>> directions.
You’re off to a good start. That’s exactly what I felt like four months ago when
I was learning. Eventually your brief standstills will be less obvious. More
like your tire just slows a bit during the launch. Mike King told me I had to
learn to hop with the cranks in any position. Like practice riding down the
sidewalk, and hop over every crack regardless of what your crank position is.
Other than that, I think your body just needs time to learn. Eventually it even
becomes easier to jump over curbs than to ride up them.
If you’re trying to hop onto an object, the idea is to pull the unicycle forward
while you’re in the air. The wheel swings an arc, so its motion is actually
forward and up, meaning you can land on higher logs and stuff. If you’ve watched
the forward rolling leaps from ground to the top of a picnic table in UNiVERsE,
you’ll notice Dan’s torso starts to bend way forward about halfway through the
jump, so that his head is at about hip-level. This pulls everything else up
higher, but I haven’t mastered that yet.
>> I’d read something the other day on a trials site about unweighting the
>> pedals. The (potentially) relevant bit to unicycling said to push down
>on
>> the pedals before launching. Do you folks that get good air do this?
Definitely you must push down HARD on the pedals before liftoff if you want to
get some air. I have also noticed that it is best not to mix pushing down on the
pedals with pulling up on the seat. The two actions counteract each other, so
you must first push down hard on the pedals until you lift off, then immediately
stop pushing on the pedals and start applying pressure to the seat. It’s amazing
how little effort is required by your hand if this technique is used. Anyway,
I’ll bet those of you that can jump rope have this technique down pat, since you
must release pressure on the pedals while the tire is still pressed against the
concrete in order for the unicycle to rebound off the ground on its own.
Chris
