Hi as you may know by now by the amount threads I have posted about muni’s I am going for the qu-ax from municycle.com but am unshore how much import tax would be on a unicycle?
It’s a 24" if that helps… o yeah I am from the uk(main land)
how much does the average muni weigh? (with slpined hub/crank)as i said earlier it’s a 24"
I tried posting this on Monday but the RSU <-> Forum link is down once again. I’ve turned to the Dark Side. Let’s see if this works…
municycle.com are in Germany. Germany and the UK are in the EU. So there’s no import duty.
Have they changed the frame yet? Otherwise it might be better to get a wheelset from municycle.com and use a Nimbus 2 frame.
Regards,
Mark.
I think the bearings which came with my municycle wheelset fitted a little too tightly in the bearing holders on my Nimbus 2 frame. In my opinion it is not a serious problem, but ask about the bearing & bearingholder sizes before you buy.
what’s wrong with the frame? i am getting it from unicycle.uk.com now so the shipping is much cheaper
You are getting the qu-ax muni from unicycle.uk.com? That sounds very cool of roger(?) for helping you out. Is this the first time hes done it do you know? And do you know if he has any plans to sell their stuff or just order through unicycle.uk.com to get municycle.com’s stuff type-thingy??
-erik
The frame is really wide at the crown and people have complained about catching their legs.
BTW, my Nimbus 2 frame fitted my QuAx wheel perfectly - no tweaking required.
Regards,
Mark.
