Re: Geared hub modification
In article <rhysling.zuqz@timelimit.unicyclist.com>,
rhysling <rhysling.zuqz@timelimit.unicyclist.com> writes:
> harper wrote:
>> Guess what. The ring gear has 90 teeth (divisible by 2, 3, 5, 6, 10,
>> 15, 30, 45 but not by 4) the sun gear has 60 teeth (divisible by 2, 3,
>> 4, 5, 6, 10, 12, 15, 20, 30). Funny, huh? SO it’s going to be an
>> offset four gear (VERY unappealing) or machine three gear cages.
> Is this a change from the first incarnation- or a just relized artifact?
> If it is a change, how did re-engenearing the planet cage effect the
> change? My poor addled brain…
I got 9/10ths of the way through asking the same question, before
going back to Greg’s pictures. The old design had SIX planets.
The new cage affair was only going to use four. While six is a
common factor to 90 and 60, four is not.
I’d recommend just doing one cage with 3 and the other with the
4-of-30 pattern, then decide later which is “best”. 'Course
I don’t have to do all the designing and machining…
There’s also a 5-gear option.
Is it clear that the planets have to be caged? The plate-with-
pins part of the old design was okay. What happens if you make a
new press-on plate then use hard steel pins and bronze bushings?
I must say, this is all very exciting! Thanks for not merely doing
this, but taking the time to show us and talk about what you’re up
to. It really is quite wonderful!
Gardner Buchanan <gbuchana@rogers.com>
Ottawa, ON FreeBSD: Where you want to go. Today.
