I have just received a new geared hub and I am having great difficulty
in hitting the upshift button. Everytime I manage to hit it I am immediatley
thrown off the uni, possibly because I have slowed down so much trying to
find the button.
Any tips on technique would be appreciated.
Practice
There is actually not a lot more to it.
Some people hit the button with their ankles, others with the heel of their shoe. Some people rub it over the button, others give it a good kick.
fwiw (I’ve only had a GUNI the last week or so) what I’ve found helpful getting started so far is:
going to a longer crank, which feels a bit goofy in 1:1 but definitely helps in making the shift to 1:1.5 and learning to ride 1:1.5.
prior to shifting gears, position the foot making the shift as needed. for me that means moving the foot in towards the crank a little and positioning the foot further back on the pedal so my ankle is in the right spot.
just as I shift up to 1:1.5 by giving my ankle a decisive flick inwards, I let off pedal pressure and anticipate the pause as the pedals slow relative to the wheel - the latter seems to help smooth the change, and have the legs ready to take the load .
I pretty much do the same for shifting down to 1:1, but instead anticipate pedaling quicker just as 1:1 engages.
So far for me shifting up to 1:1.5 is lot smoother and more enjoyable. Shifting down to 1:1 seems like a lot of crazy spinning after the high gear. The main glitch hasn’t been falling off when changing gears, but making reliable contact with the shifter button, which isn’t a biggie as I just try to shift again next time around.
I’m using low shoes atm, I’ll probably get some mid’s/high’s so life is bit easier on the ankles shifting.
Apart from my usual riding I aim for a session each day of just riding back and forth changing gears, along with some easy runs in 1:1.5, trying to keep it smooth and getting a feel for how to control it etc. Takes a bunch of concentration atm.
My initial impression is that the jump from 1:1 to 1:1.5 could be too wide for a lot of off road use which is mainly what I do … maybe something more like 1:1.3 might be more useful during a ride, but that is probably due to my lack of experience on the GUNI.
I wrote a thread about this a while ago:
Geared Hub Advice
Thanks for the advice guys, already there is a big improvement.
