I am constantly being asked whether the Nimbus II frame will fit the
Gazzaloddi 3" tyre in the frame.
The answer is yes.
Here is the evidence, not loads of clearance but certainly enough. The 28"
frame will even fit the 26x Gazzaloddi 3.0, but the picture shows the 24" www.unicycle.uk.com/images/28nimbusiiwithgaz.jpg
We have a limited stock in the UK of the 28" frames, we will be fully
stocked by the middle of March though. For those in the US I am sure that
you will have this cheap option available quite soon.
At the moment the 24" Nimbus II is only available as a complete uni…
unless Roger (on his holidays at the moment) has some spares lurking
around. There’s a new shipment coming in some time in March I believe so
there should be some frames in with that. As for when they’ll hit the US
John Drummond’s probably the man to ask.
Cheers, Neil
P.S. It’ll fit a Profile
----- Original Message ----- From: “unicyclejoe”
<forum.member@unicyclist.com> Newsgroups: rec.sport.unicycling To:
<rsu@unicycling.org> Sent: Friday, January 18, 2002 8:25 PM Subject: Re:
Gazzaloddi 3.0 in Nimbus II frame
> Does it realy come in 24 inch?. on unicycle.uk.com they only have it in > 20 and 28 if the 24 is real that is awsome > > i also need to know, is the nimbus 2 frame work with a profile hub > > and lastly WHEN IS IT COMING TO THE U.S i need to be able to get it > before june > > JOEY > > > > > – > unicyclejoe Posted via the Unicyclist Community - > http://unicyclist.com/forums >
_________________________________________________________________________-
__ > rec.sport.unicycling mailing list - www.unicycling.org/mailman/listinfo/rsu
