Will the gazz 24x3.0 fit on the standard kh freeride rim? Udc site says you need a double-wide rim, like the sun I would imagine. I believe that the standard kh freeride frame will accomodate the gazz, just not sure about the rim.
yes
Yes it will. I had a Gazz on my Alex rim for a week and it was good. And the Alex rim is only 32mm wide and the KH is 42mm wide i believe
It will definitely fit the rim. It is in question whether it will fit the frame. There were 2 different frame lengths released in '05. The shorter one will not fit a Gazz.
I’ll have to check on that. Thanks.
