At the moment there are many games out there but i think one important is missing:D:
Combo Stack it up
A little explication:
Player 1 sets a trick for example: wrap walk
Player 2 has to do wrap walk and another trick after wrap walk
It has to be a combo
Hop on wheel is allowed
You are allowed to add a trick at the beginning and at the end
So let’s start!!
-Ludwig
who will add the first trick?
is it ok if i add 90 180 wrap roll or are this too much tricks?
2nd trick?
oh i didn´t saw the second trick
mine is uploading i did a 270 90 before the wraproll
http://vimeo.com/4574642 yes with hops because i have to change my hand positioning and i need hops for that
Wasn’t this done a little while back?
Alright here is another Game to play. This is similar to the Uni Tricks Clips game but not the same. Here are the rules.
The first person does one trick, not a combo. The next person then has to do the first persons’ trick and then there own trick in the same combo. The 3rd person will then have to do the first and seconds persons trick and then there own trick. This then continues with people adding on tricks until the combo gets too long/hard to do.
Here is a example:
Person 1 does a 180 un…
but it´s not the same here all must be in a combo and there must be all tricks in one video:)
buchi
May 10, 2009, 10:48am
#15
ich hab weiter gemacht
I continued …
here the vid
http://vimeo.com/4576899
i want to do the next trick please
then do it does somebody wants to go on at the biu roll?^^
did you add 90 or 180 to backroll?
i think you can do both;)
ill combo that unless someone else beats me too it
