I can’t figure out how to set up my album/gallery thing. How do I put pictures and movies in it?
please help me
When you go to your empty gallery look on the left side. There should be a bunch of options in a menu type thing. It says:
To add pic/vids click on add items and then just upload your file.
If you don’t see that menu then go to the bottom and see how you are viewing your gallery. If it says guest then click on Mornish then you should get your options.
ok thanks. also, how do I make seperate albums, like an album of all my unis, that you clickon, and it takes you to seperate images?
Click “Add album”
When you are in your gallery on the left side click “add album”.
That will make a subfolder. You title it and it will go in there. Using that button you can make folders inside of folders and stuff.
Fine, Gilby beat me. I guess I wrote more than I needed to.
ok thanks.
also, spencer: how did you set up your gallery so that you can put
www dott unicyclist dott com slash gallery slash spencer???
I don’t remember. I just looked and can’t find it.
ok thanks anyway. I just took a bunch of pics of my trials uni and will upload them as soon as I figure out how to use the camera with the computer.
