Fusion Saddle
Were do i get a fussion saddle and are they any good.
Im pretty sure you can get them from unicycle.com, but there kinda thick and get ur butt sore after awhile of riding.
I switched to a KH gel saddle and there skinnier less weight, and much more comfy
I think those are on unicycle.com also
If ther still there
The good thing with the fusion cover is that you can modify your seatfoam easily…
But if won’t be THAT confty for muni riding, pretty good but not enough.
I would go for the gel seat if i had to make the choice for myself. :slight_smile:
I used to ahve a fusion saddle and loved it. Only problem with it was the seat base witch isnt the strongest…
The new Fusion saddle, which I have, is probably about 60% as thick as my old-style KH. The dual-layer foam is twice as comfy, and it’s really stiff (at least for a KH, these still aren’t carbon fiber or anything).
check to see if it’s the new dual-density foam before buying, and you’ll get the one I described above.
