Aaauggh, I DO NOT need one of these, I DO NOT need one of these, I DO NOT need one of these, I DO NOT need one of these, I DO NOT need one of these, I DO NOT need one of these, I DO NOT need one of these, I DO NOT need one of these, I DO NOT need one of these, I DO NOT need one of these, I DO NOT need one of these, I DO NOT need one of these, I DO NOT need one of these.
How are you at coasting? That’s something you could practice on a regular unicycle to see how much you’d like it. I love coasting and the freewheel unicycle gives me the ability to do it longer and in more locations. It’s also great exercise! While coasting in general works the core as you’d expect freewheel unicycling particularly works the lower back.
I don’t want to discourage you from learning to one foot wheel walk, but I would say that it’s not a prerequisite for coasting. Nice, smooth one foot riding really helps, but if you have it down at least somewhat you’ll improve as you practice coasting. My left foot was originally my weaker foot for one foot riding but after a lot of coasting practice it’s better than my right foot.
What’s your definition of not working? For the Nimbus hub I believe Roger is figuring out the offsets that may needed to fit washers to offset the caliper. I have a line on another drift trike hub with 100mm bearing spacing but it has 32 holes and I’d prefer to stick with UDC if possible.
The problem with a larger wheel for me is the learning curve and risk of injury. So far I haven’t had any major falls (knock on wood) but the potential is there. So many times I can just shrug my foot off the pedal to the ground to make a save. I also wonder about the benefit of a larger wheel. I imagine it makes it easier to absorb bumps and rough terrain but on a 20" wheel it’s already easy to go faster than I can control. I’m not sure if the balance will be different on a larger wheel. I was surprised how much control I have on a freewheel vs. coasting on a regular unicycle.
I’ve been planning on building a 24" wheel because I have an extra hub with 48 holes and I have a 24" Nimbus II I could cannibalize. However, that wouldn’t have a brake so I may need to rethink that strategy. A 26" would probably make the most sense.
I have no idea about coasting, I have never tried, so for me this would be a new trick, and if I want it to work it’ll need to be usable on the trails with my feet on the pedals so I can pedal as needed.
Is the Nimbus hub spaced wider than 100mm? And is the bearing also 40mm vs 42mm Nimbus standard??
I’m not sure that coasting is a prerequisite for freewheel unicycling but I would recommend at least some practice with it. Looking at my videos and based on experience the body corrections are very similar. It’s almost a cross between one foot on frame coasting (which I’m not very good at) and two feet on frame coasting (which I’m decent at). With one foot on frame coasting for me the balance corrections take place by moving the unsupported leg. For two feet on frame coasting the balance corrections come from moving the torso forward and back (although the feet do a little bit). Coasting on a freewheel unicycle lets you swing your bottom foot forward and back but most of the balance corrections come from the upper body. I started practicing coasting in February 2012 and after a few weeks I did this video:
Those are decent runs but they were not very frequent at that point. Another year plus of practice got me nice long runs more frequently:
Since I got my freewheel unicycle set up I haven’t practiced regular coasting (I count it as my coasting practice). I think I’ve mentioned before that it has the fun parts of coasting but with longer runs and less remounting. Plus, no startup!
The bearing spacing on the Nimbus drift trikes is 100mm and they are 40mm diameter as you mentioned. I believe they are meant to be used for penny farthings unless UDC is going to start selling drift trikes (the name gives their original purpose). I know some other sources for hubs, too.
I wanted to thank everyone for their input and feedback, in this thread, another one I created asking about disc brakes, and the original thread that spurred me to build my freewheel unicycle (jona and lobbybopster, especially). I’m going to backpedal a bit from the idea that coasting be such a big part of it. That’s the place I went to because that’s my background and I had no experience with brakes until recently. There were certainly suggestions about a brake but I was fairly skeptical how much it would help except to slow down on an incline. However, as I get more practice with it I’m finding it to be much more useful. Pedaling is probably the most stable action but not a lot is necessary to get going at speeds I was comfortable with which meant a little pedaling and a lot of coasting as demonstrated in my first two freewheel videos. Using the brake more lets me pedal more. I can pedal to get to a speed beyond which I’m comfortable simply coasting and then use the brake to get more control. I can also use the brake to control turns more easily. I’m planning to practice a few more weeks with the brake and I expect I’ll be able to go faster and take on paths and terrain that I cannot at this time. I’ll make sure to make another video with my progress. By then I may also figure out if I can order a disc brake compatible freewheel from UDC and decide on a wheel size.
Freewheel unicycling on Santa Barbara Road Redux 7-1-2013
Here is the brake coasting version of “Freewheel unicycling on Santa Barbara Road”. On the previous version I coasted only and didn’t use the brake. It’s less arduous and requires less concentration and balance adjustments. It almost looks like regular unicycling except I’m touching the seat more.
Thanks! Riding at this slow speed on concrete or asphalt seems fairly easy to me now and I can go for decent time without a UPD. I want to work on getting my speed up and getting better off road. A path with packed dirt and small rocks is pretty easy, too:
This is sooo awesome… I’ve got a spare cotterless (24") frame and cranks, basically everything but a hub which is broken. I’m extremely tempted to buy that nimbus hub now that they are available at udc!
