I have Yuni one and i would like to learn stand up style tricks, so the question is assumig Paul Wyganowski frames too expensive do you think upgrading my yuni one into a Semcycle XL or even a Semcycle XL 20-inch Long Neck is necesaire or the yuni one is good enough?
From what I’ve heard (not owning one myself), the Semcycle XL long neck is the preferred freestyle frame. Because it has a longer neck, the seat post clamp is higher, so won’t hit your legs as often. There was a discussion about this before; you might be able to find the thread with the search function.
Good luck!
Yo!
The best frame for freestyle is definetly the Wyganowski. Yes, it is expensive but lasts a LONG time and holds up really well for advanced freestyle tricks. The second choice would be a Miyata, quality. I f you want the longer post, I’ve heard Semcycle XLs work good. But if you want a long time investment, the Wyganowski is the way to go.
Ryan’s not that short. You don’t need the seat clamp to be all the way up under the seat, so growing is not a problem. If you wanted to lenghen the frame you could probably send it back to Wyganowski for an upgrade. Since the things don’t come in chrome ( ), repainting is probably not too hard.
