freerider 2
That link to the track is really impressive. Must have taken them ages.
And 9.0 seconds! well done.
-18 1i 18 1i,-18 1h -1d j,16 1j gb 1s,gc 1s i0 1n j3 1e jp 13 ke i l4 -4 lj -k lv -15 ma -1v mh -2h md 1t n1 1r ns 1q,ou 1q mg 1q,os 1t pn 1r pv -ag tp -ac,q0 -af q0 -b3,q1 -b3 tt -b0##T sk -bl
I managed it once.
It’s a real challenge.
i got it twice already
hehehe, I did it! :slight_smile:
My god! everyone in this thread seems to be so perseverant. I guess we wouldn’t be unicyclists if we were not.
Got it after 3 tries.. yay.
woah, got it in like, 87 tries! lol it was hard
Well i had to win by using the ??? object. :stuck_out_tongue:
I worked out it’s possible with the mountain bike and the truck as well (and it’s quite hard with the blob) but it was intended for a bmx.
With the unicycle I can only just make it over the launch ramp.
Where did you died?
I did this level because I had nothing to do. I did VI.
-18 1i 18 1i so bi vi c6 122 cg 148 cg 164 c6 17m b8 18k a0 19i 8e 19i d4 19i do,19i d4 -u d4 -u 1s -1i 1s -1i -2g -18 -2g -18 1i,19i d4 1v4 d4 2bu d4 2dg d4 2dg 8o 2eo 8o 2eo d4 2dg d4,1b4 d4 1b4 de,1cm d4 1cm do,1e8 d4 1e8 de,1fq d4 1fq do,1hc d4 1hc de,1iu d4 1iu do,1kg d4 1kg de,1m2 d4 1m2 do,1nk d4 1nk de,1p6 d4 1p6 do,1qo d4 1qo de,1sa d4 1sa do,1ts d4 1ts de,1ve d4 1ve do,210 d4 210 de,22i d4 22i do,22i d4 244 d4 244 de,25m d4 25m do,278 d4 278 de,28q d4 28q do,2ac d4 2ac de,2bu d4 2bu do,1cm e2 1cm ep,1cc e0 1ct e2,1cf ek 1cr ep,1fi e0 1fi em,1fs e2 1fs em,1fe dv 1g2 e2,1fb ek 1g4 ek,1im dv 1im ef,1iu e0 1iu ej,1j5 e2 1j5 ej,1ih dt 1jg e4,1i8 ec 1jd ek,1lm e2 1lm eo,1le e2 1mm e2,1lb eo 1mm eo,1lr e2 1m4 eo 1mc e2,1oq dv 1pq dv,1ov dv 1p8 ep 1pg dv,1os em 1pl ep,1rk dt 1rt eo 1s5 dt,1sh dv 1sf eo,1re dr 1sp dv,1rj eo 1sr eo,1v2 dt 1v6 et 1vg dv,1vo dv 1vo er,202 e4 204 et,1ut dt 20f e2,1us et 20h er,21s dv 21s er,226 e2 228 ep,22f e2 22v ep,231 e2 22f eo,21m eo 239 em,239 e2 21k e0,25a e0 25a eo,25h e2 263 ep,262 dv 25e eo,252 e2 26k dv,24v em 26d eo,28j dv 292 ep,291 e5 28d eh,28b dt 299 e7,284 eh 299 er,2bm dq 2c1 em,2c0 dv 2bk ej,2cd dt 2c6 eo,2bd dr 2cl dv,2bd eh 2cg ep,2dg cq 2eo cq,2eo cg 2dg cg,2dg c6 2eo c6,2eo bs 2dg bs,2dg b8 2eo b8,2eo bi 2dg bi,2dg au 2eo au,2eo ak 2dg ak,2dg aa 2eo aa,2dq cq 2dq d4,2ee cq 2ee cg,2dq cg 2dq c6,2ee c6 2ee bs,2dq bs 2dq bi,2dq b8 2dq au,2dq ak 2dq aa,2ee ak 2ee au,2ee b8 2ee bi,2dg a0 2eo a0,2eo 9m 2dg 9m,2dg 9c 2eo 9c,2dg 92 2eo 92,2ee aa 2ee a0,2ee 9m 2ee 9c,2ee 8o 2ee 92,2dq 92 2dq 9c,2dq 9m 2dq a0##O 2bu cg,O 2ac cg,O 28q cg,O 278 cg,O 25m cg,O 244 cg,O 22i cg,O 210 cg,O 1ve cg,O 1ts cg,O 1sa cg,O 1qo cg,O 1p6 cg,O 1nk cg,O 1m2 cg,O 1kg cg,O 1iu cg,O 1hc cg,O 1fq cg,O 1e8 cg,O 1cm cg,O 1b4 cg
Where did you died?
I did this level because I had nothing to do. I did VI with the BMX.
6.5
-7q 4m a0 4m,-7q 4m -7q -a0 a0 -a0 a0 4m##B 3o -3e 7i,B a -5k 6m,B -1s 0 3e,B -2g -2q 4f,B -6i -42 45,B -4c -4m 5b,B -4m -6i 4t,B -5u -6i 4e,B -2q -8o 5n,B -5k -76 4d,B u -26 8r,B 5a -k 8q,B 68 -3o 72,B 2g -5k 57,B u -6s 5k,B -1s -8e 50,B -a -7g 6o,B 7g -3o 8i,B 9c -34 8d,B -a -2g 81,B -4m -1s 2m,B 1s -2g 87,B 8o -5k 7o,B 6i -8e 7f,B 68 -8e 75,B 2q k 95,B 7g -a 9c,B -34 -50 3m,B 5k -68 7j,B 3e -18 2h,B -2g -4c 43,B a u ac,B -2q a 3b,B -a -34 6r,B -34 -k 1d,B a -42 6t,B -50 0 2e,B -k -3o 6v,B -4m -1i 3u,B -4c -3e 3o,B -42 3e k,B -2q 26 p,B 1i -18 i,B u -k t,B u -a i,B k -1s 1d,B 1i -1s 66,B 26 a ai,B 1i 34 9,B 3e 34 b8,B 3o 2q 5,B 4c 3e b8,B 5a 2g b8,B 5u 34 aq,B 68 3e b8,B 7g 42 b8,B 7q 3e b8,B 7q 4c 6,B 76 4m i,B 68 42 e,B k a k,B -u 2g ap,B a -9c 5k,B 8o 1s 88,B 8o 18 83,B 7q -26 7q,B 92 -3e 7q,B a0 -4m 7t,B 92 -6i 7h,B 9m -92 7c,B 8e -9m 5v,B 5k -9c 5b,B 3e -9c 59,B 1s -9c 5v,B -4m -9c 4p,B -1i -9c 77,B -3e -9c 57,B -6s -9c 4u,B -76 -7q 3l,B -76 -5u 3b,B -76 -3o 2q,B -6s -1s 2q,B -6s -a 2c,B -6i 26 1q,B -2g 3e an,B -26 3o b8,B 0 42 7,B 1s 50 aq,B 50 4c ad,B 6i 4c 9j,B 9c 3o 9j,B 8o 4m a3,B 4c 42 1d,B 26 42 1d,B 0 4m e,B -1s 50 12,B -3e 4m r,B -4c 50 r,B -5k 4m 1d,B -68 4m ad,B -76 4m b8
:slight_smile:
34.044 :):slight_smile:
-18 1i 18 1i,9n 2a 9s 2v a0 3m a6 4c ad 54 aj 5s aq 6l b7 7h bt 8f cl 9f di ak ej bs fg ct gf e0 hh f1 il g3 js h3 l6 i0 mi iq o1 je pe js qm k3 s0 k6 t3 k5 u4 k1 v5 jp 109 jf 11i iu 12v i9 141 hj 14r gj 15b fi 15k em 15l dm 15k cq 15j bv 15t b3 16o bl 16u ck 173 dj 174 en,vg 52 10d 59 11e 5h 12c 5p,172 eb 17o et 18c fj 18r gg 19d hi 1a2 ir 1ao k2 1br le 1d3 ms 1ef ob 1fu po 1hh r4 1is s3 1kb su 1lt te 1ng tq 1pk u5 1rp ub 1ts u7 1vu to 21p su 235 rp 23p ql 247 pf 24m r0 247 sc 23j tt 232 v6 22u 10e 24d 10a 258 v7 25u tv 26i sr 279 rf 280 qc 28t pd 2aa ot,vj 52 tb 4e,2af ov 2ai pn 2ar qg 2bc ra 2c1 rt 2co sg 2dl t3 2eq tq 2g3 u9,2fs u6 2gl ub 2hj uh 2ij uk 2ji ue 2kg u1 2lb tf 2m1 sq 2mr rt 2nn r5 2oq qh 2ps qg 2pr rj 2ou sl 2o1 tg 2n9 uf 2nm vm 2oq vr 2pr v9 2ql uh 2rc ts 2s0 vf 2sc 10p 2t1 11j,2t3 11k 2t3 10l 2t3 vo 2t3 uq 2ta tr 2tt t3 2us sk,38s 165 3ah 17e 3c8 18i 3e0 19e 3fm 19t,3fj 19s 43o 1a5 46f 1a5 46f 1b9 47l 1bb 47l 1ch 490 1ch 490 1dm 4bf 1dm,4bk 1do 4bk 1gt 4fe 1gt 4fe 1k9,4fq 1k9 4jo 1k9 4jo 1mv 4ns 1mv,49v 1b4 4tg 1n7,4bm 1go 4du 1dk,4jn 1mr 4mk 1j3,4ni 1mo 4ni 1ql 4td 1qg 4tb 1ub,4tb 1u8 5j6 29c,2uo sj 2vj sm 30i t1 31i tn 32f uj 335 vf 33q 10e 34e 11c 356 12b 360 13a 371 14b 387 158 39h 168,39g 16d 38s 168,5j1 299 615 2ce 6cd 2cs,6cb 2cs 6ko 2cu,6ko 2ct 6lc 2ct 6m2 2d5 6mj 2dp 6mr 2eg 6mt 2fb 6mv 2g8 6n1 2h8 6n3 2i6 6n7 2j3 6nh 2k8 6nu 2lc 6of 2mk 6p3 2o0 6pr 2p3 6qn 2q0 6ro 2qo 6sl 2r9 6tj 2rq 6uo 2s9 6vr 2so 717 2tb 72g 2tn 73u 2u2 75g 2uc 775 2uk 78s 2uo 7ak 2um 7cd 2ud 7e7 2tv 7g0 2tc 7hn 2sj 7jb 2rm 7kq 2qj 7m9 2pe 7nn 2o7 7p1 2ms 7qb 2lg 7rl 2k4 7sv 2io 7u7 2hb 7vd 2fv 805 2ee 80t 2cs 81q 2bp 82o 2bc,82k 2ba 862 2bb,867 2ba 862 2bb,865 2ba 867 2cr 87p 2cr 87n 2e4 896 2e4 894 2fj 8b7 2fl,8b8 2fj 8b7 2ha 8ej 2hd 8qt 2mb,87l 2e8 892 2cm,8bd 2h9 8cg 2fq,87g 2bl 8dt 2g4,8cs 2fb 8cb 2fv,-1b 1j 9l 1j,9l 1m 9l 2h,8qv 2m9 8rs 2mj 8sv 2mv 8u3 2na 8v8 2nm 90f 2nv 91q 2o5 936 2o9 94i 2ob 95t 2oa 977 2o5 98m 2nr 9a0 2ne 9bc 2mt 9cq 2mc 9e9 2ls 9fd 2l7 9ga 2kd 9h5 2jv 9h7 2l9 9g9 2mh 9ff 2ni 9ec 2om 9de 2pl 9cl 2qd 9bu 2r5 9d6 2r7 9e4 2qe 9f3 2pn 9fv 2p2 9gp 2oa 9he 2nh 9hu 2mq 9ia 2m6 9ip 2lg 9ja 2ks 9k3 2ku 9kq 2ld 9l4 2m4 9ls 2m6,9pb 2kk 9qh 2l1 9ri 2lo 9sh 2mp 9tl 2o0 9us 2p9 a09 2qf a1o 2rd a38 2s2 a4r 2sj a6e 2t1 a83 2tc a9k 2ti aat 2ti ac3 2th ad1 2te ads 2tc aek 2ta af9 2t9 afq 2t7,9n2 2lv 9no 2mn 9oh 2ni 9pb 2oc 9qb 2p5 9ra 2pn 9rh 2ok 9qr 2nr 9q6 2mu 9pk 2m4 9p9 2la,9n3 2m0 9mt 2la 9mb 2lp 9lv 2md,9p9 2l9 9pb 2ko,afk 2t8 agj 2t2 ahl 2so air 2sb akc 2ro alj 2qu amr 2pv ao3 2ot ap9 2nj aq4 2m2 ar0 2kg arn 2iu asv 2j5 asn 2kn aro 2m8 aql 2nq apf 2pj aok 2r0 apv 2qe aqq 2p4 arl 2np asi 2me ato 2ku av3 2jc b0f 2hq b1d 2gt b2k 2hc b3o 2h2 b4b 2g0 b4c 2ej b3v 2d8 b3i 2c5 b31 2b8 b26 2ac b0v 29r avj 29g atu 29a as4 29f aqe 2a3 ap0 2b7 ant 2cj an1 2du amq 2f4##T b1i 2ec
I can’t even do it! is it for the BMX?
EDIT: NOO! I died right before the star!
Better place to play FR2
Hey, if you really want to play this game you have to visit: http://trackmill.com/free-rider-2/index.php
After almost two/three years of being addicted to the game I can say that it is an awesome site to play Free Rider 2. You can play other peoples’ levels and even submit your own! You will be surprised at the crazy art work and difficulty of some of the tracks. There is also bonus vehicles such as a wheel-chair and skateboard. Just thought I’d let ya’ll know…
yeah, track mill is awsome, and the Wheel chair is awsome, I can do a front flip on flat with it. I love Freerider 2 when I have nothing to do:p
You can slam on the brakes, lean forward, and land it only when there is a small ledge to go off of. You can’t do it just on a straight line, can you?
Yes I can on flat, without the little small legde:)
-18 1i 18 1i,18 1k 18 3v,3o 42 3o -18 -18 -18 -18 1i,18 42 -u 42 -u 92 42 92 42 9c 9c bi ec bi gi a0 gi bi k0 bi k0 aa ku bi qs bi qs ec,3o 42 3o 50 26 68 84 68 84 76 au 8e kk 50 10q 50 148 e2 qs ec##T vs d4
5.08 sec
really frustrating short level
No way. I tried it with the ???blob and couldn’t get that time.
