Freemounting- easier said than done
OK so I want to learn freemounting A.S.A.P, since it is pretty much essential for any uni rider, why not get it out of the way early when I learnt how to ride.
Now and again I am able to freemount and ride off, but I am having frequent problems:
-Sometimes, I just stall when free mounting because of the position of the pedals are exactly 12 and 6.
-When I mount on, I find myself missing the pedal as it rolls backwards.
I know a lot of advice is to take weight off pedals, but this is easier said than done, where should I distribute my weight as I am mounting?
When I was learning, I just went to You Tube and asked for “freemounting unicycle.” I got several helpful tutorials. You can also do a search here for freemounting, or free mounting. I’m not sure if it’s one word or two.
Look, to be honest, when I was learning freemounting I would only get about 1 in every 5 or 6 that I tried. To get used to it i just held onto a pole and got up onto the uni and then stepped off and did this over and over again.
After a while I tried experimenting with different pedal positions as well. :slight_smile:
Once you are comfortable doing this move away from the pole.
As for weight distribution, think about pushing the seat of the unicycle into the ground with your butt and just lift your feet onto the pedals.
Have fun and remember, everything is easy if you take one small step at a time! :slight_smile:
Simple Mount
Here is a simple mount that most people to not attempt until they have learned several other mounts. You could set a trend and learn it as your first mount!
On the up side, you do not have to decide which foot is your dominant foot or how to step up.
http://www.youtube.com/watch?v=vTyOT3SjJMM
On the down side, you may never be a father. :frowning:
Good luck with learning to mount. I found grabbing the wheel helpful when learning, and that mount has been discussed elsewhere.
Scott
Before worrying about the freemount, make sure you are comfortable with the riding-away part. Otherwise you’re just wasting a lot of effort (and time). When you can turn left and right, go where you want and control your speed, then work on the freemount. Until then you can ride away from the curb or similar…
For further instructions, you can also use the search function in here to find reams of help. Short version:
  1. Try not to let one foot stop at the bottom (yes, it’s hard).
  2. Don’t try to be balanced when mounting; be slightly falling forward.
I could not figure static mount because of the weight on seat part, so I learnt the roll-back mount. It does not require as much weight on the seat from the start. I kind of jump up a little behind the center of gravity and try to push the wheel back with the upper pedal. Works every fourth time :slight_smile:
Step 1: put dominant foot on closest pedal (typically one at either level or down an extra 45 degrees from level) this will push the unicycle under you, slowly ease your weight onto the pedal
Step 2: put other foot on.
Step 3: balance.
For me it was easier to learn the standard static mount by grabbing the wheel as I stepped up. In fact I could freemount before I could ride 20m. Try not to think about it to much and keep the weight off the pedals.
I am resting my uni against a patio to help (it keeps it still, and I learn to get the balance right)
And I tried the seat thing, but still find myself putting pressure on my foot.
I will not learn suicide mount as a beginner! lol, and my friend recomended the tire grab, but I find static mount much easier.
When free mounting, I am successful about 1/10 times. When I rest my uni aganst my patio (instead of the curb) I ride away 3/4 times, I will try the leaning forward thing
Hmmm, I start by putting my left foot (none dominant) on the pedal, and I lift off with that to get my right foot onto the other, would that work? I use the power in my right foot to start pedalling
I’m having trouble where I put all that weight, since when I’m mounting it all goes onto my left foot which makes the uni move.
It will initially until you learn how little weight you need to put on the pedal to keep the wheel stationary. In order to combat this in the early stages, reach down and grab the wheel with one hand so that when you step up the wheel is kept stationary by your hand. Stepping up then becomes easy and you have time to gauge things. Then simply start pedaling and sit up straight. It’s not that difficult and no you won’t bail straight onto your head :). After a while you will get used to the weight and pressure required on the pedals that you will no longer need to hold the wheel with your hand.
If you think of it as hopping up onto the unicycle instead of stepping up onto the unicycle, you may have more luck with static free mounting.
Free Mount
+1
Yup :slight_smile:
Just try not to think about it. Watch some videos of people doing it, sorta look at the detail, and then just do like you see. lol.
It helps to have a wooden leg
The low pedal is angled back at you, don’t step on it. Make that leg wooden, your peg leg just blocks the pedal, keeping the uni from rolling when you do the jump with the rear leg to the forward pedal. If you step on the back pedal, the uni of course will roll back. Just make the first leg stiff as wood. It just blocks the pedal, it doesn’t step on it.
You seem to be trying to combine elements of both rollback mount and static mount, and this possibly confuses you because the two techniques require a different approach. I think most beginners find static mount easiest. Then indeed your question of where to put your weight in the initial phase of the mount is relevant. You should include the dynamics of the process. So you kind of jump up using your back foot, the one on the ground. Your body is kind of ballistic, as a ball in its orbit, and will follow this trajectory without putting any weight anywhere. (Well in fact some weight is on the seat, and some on the back pedal.) Then you land your second foot on the pedal - remember this is a STATIC mount so the pedal is still in the front. At that point put about equal weight on both pedals, so that your ballistic orbit stops - meaning that you don’t go down but only forward. Your forward momentum should continue for a while so that your centre of gravity gets somewhat in front of the tyre-ground contact. Then pedal off to the front, in order not to fall forward. I hope this answers your specific point about where (and when) to put your weight.
If you are successful already one in ten tries, you’re getting it. Practice, repeat, repeat.
When I was learning the static mount I tried a few times just to jump like I was mounting but I was not putting the leg on forward pedal just landing in front of the uni. I’ve did that to get a catch of the point when I should stop. I think it helped a bit.
I think I understand what people are saying, lift off with my right foot (like when walking up stairs you normally put weight on the foot in front of you, instead you use the foot behind you to lift off)
And thanks :slight_smile:
Try mounting on a slight hill. I tried that and got free mounting my first day trying it.
Make that a DOWNhill. Mounting while facing up is more difficult that on the flat.
Besides what everyone has told you here, people I know who started riding have found this a useful video for learning to freemount…
Sometimes at least for me,it is easier if I can see it being done than read it and put it into action. Good luck but don’t put too much pressure on yourself immediately it will come like everything the more you ride the more confident you will become and the easier you will find things coming together.
