FreeBSD vs RedHat Linux
Which would make a better server os?
Rodney Blackwell - http://www.5r5.net
“I’m the latest craze” - Macy Gray
Re: FreeBSD vs RedHat Linux
For security, Id choose OpenBSD (Only one remote hole in the default
install, in more than 7 years).
For Webserving I’d choose Mandrake. Mandrake has pre-optimized apache, and a
better RPM setup (urpmi).
But that’s not what you asked :wink:
Both FreeBSD and Redhat are good choices. Id lean to redhat easy to find
support, prepackaged rpms for easier updating, option for commercial
support.
John R. Marshall
The Hotrodding Network is Back!
Thanks John…
related question:
How many times better is this server spec performance-wise over a raq4?
“Pentium 4 2.4GHz processor, 512 megabytes of DDR RAM, 60 gigabyte hard
drive, Intel Pro 100 Plus network card, and your choice of FreeBSD or RedHat
Linux operating systems”
“John R. Marshall” <hotrodder@softhome.net> wrote in message
news:bhun1p$4rm$1@www.darklock.com
a
> support.
> John R. Marshall
> http://www.hotrodding.net
> RedHat Linux operating systems”
Umpteen times better :slight_smile:
But really it all depends on the server, the raq was built to on 24/7. and
if your looking at a white box server it might not be as reliable. But the
extra horsepower on that server will be nice if your running alot of
perl/php/mysql processes. (I have see a popular forum bring a dedicated
server to it’s knees.)
I’m REALY tempted to get a server and start hosting… right now
http://www.serverbeach.com is offering a debian server… I really like
that idea.
AMD 2100 XP Athlon
1GB ram
900 GB Bandwidth
Free setup $119.00 month
John R. Marshall
news:bhv866$nlb$1@www.darklock.com
That seems to be my problem, since one of my sites uses a lot of php/mysql
processes.
What do you mean by a white box server?
I think it may be time for me to leave the raq race.
Rodney
Where’s a good place to buy a server?
For the bandwidth I need, it looks like colocation might be cheaper.
Rodney
a white box is a server in a normal tower case.
John R. Marshall
Yikes! how much bandwidth do you use a month??
John R. Marshall
How much do You need?
I need about 40 GB per month
Roland Mösl
http://www.pege.org Clear targets for a confused civilization
http://web-design-sutie.com Web Design starts at the search engine
For you, or for an experienced server admin? I think Redhat makes a
great server OS, and is much more useable. Some (like JRM) might argue
that FreeBSD is more secure/whatever (and they may have valid points),
but I don’t think those points make much of a difference.
With a little bit of reading, you will be able to run a secure, stable
Redhat installation. I’d recommend looking into Redhat Linux Enterprise
(not free, but built for servers, not desktop use). It’s not necessary
for what you’re looking into, but you’ll get a little bit better
support, etc.
Either way, they are both worlds ahead of Cobalt.
-Mike K.
> Thanks John…
> related question:
A Raq doesn’t even compare to that :slight_smile:
-Mike K.
RedHat
But the CPU
I would more like a system with a Centrino 1.4 GHz
Roland Mösl
“Mike King” <webdiscuss@webcodefocus.com> wrote in message
news:bi00q4$hue$1@www.darklock.com
hehe…good follow up question :slight_smile:
Yep, for me. I don’t want anything that’s going to require a rocket science
degree to administer sites.
Rodney
news:bhvcg7$rt6$2@www.darklock.com
Actually more than I thought. Colocation is going to be more expensive than
I thought.
I thought I was around 10-15 GB a month, but it’s more like 45-60 GB a
month.
Rodney
I would stay the HELL away from Red Hat (and I do!). RPMs need an
overhaul to intelligently fetch dependencies and install them.
But you’re in luck. You can install Gentoo over-top of Red Hat
(http://forums.gentoo.org/viewtopic.php?t=28559 or
http://tinyurl.com/kneo).
-Lisa
“Lisa” <lisa@thedoh.com> wrote in message
news:pan.2003.08.20.20.48.00.751575@thedoh.com
you’re somewhat of a gentoo zealot aren’t you :slight_smile:
It’s all about APT, man :slight_smile:
-Mike K.
Mike King wrote:
>>[color=darkred]
> -Mike K.
>[/color]
Well if you cannot install APT, what can you do? :wink:
There is absolutely no problem installing APT on a modern Redhat
installation. (which Rodney should have when he gets a new server).
Cobalts, on the other hand… :-p
-Mike K.
>>[color=darkred]
> than I thought.
> month.[/color]
You dont need colocation. you can rent a servre at serverbeach.com that will
give yuo 900 GB a month. far more than you need :wink:
Oh can you tell I like serverbeach? :wink:
John R. Marshall
