Free-mounting on small surfaces
Right now, I can easily free-mount on the sidewalk by putting my dominant foot on the corresponding pedal and then rocking.
Now, how would I free-mount on small surfaces in which rocking means falling off (ie railing)
How do people like KH and Dan Heaton mount?
When I mount on skinnies, I put my back foot on the pedal, and my front foot about 10cm away from the back of the tire. I quickly mount and start pedaling forward right away. From there, riding on the skinny is all about confidence and commitment.
The super-awesome-insanely-good riders are able to slowly pedal along the skinny, but when your just starting, it’s a good idea to ride with some speed.
It sounds like you’re currently doing rollback mounts. A static mount will get you on top the unicycle without much wheel movement. I’m not good enough to mount on a small surface yet, but there’s a big difference between my rollback and static mounts in terms of wheel movement. I found this short clip comparing the two: http://www.unicyclist.com/gallery2/main.php?g2_itemId=197387
I tried static mount…
works great!
thanks
I had issues with the static mount (on KH24", but also on the noname 20" I used before). It simply did not work for me since I could not stop my foot from the reflex to push down the pedal. :o
Recently I did, however, a (for my level) quite extreme long downhill tour, partially on single trails, steep with lots of stones and roots . Since I UPDed quite frequently it turned out as well to be a good mounting execise. Due to the steepness it was actually very straight forward to do static mounts.
Back on flat territory I could still do it. Since then this is my standard way of mounting. :slight_smile:
yea i roll bak mount on rails lol .
