Frames and monty wheel
Speaking of frames, for trials, the united - mounted on a monty setup is
kind of real real close of the tyre. I bent the wheel a bit after repeated
drops and now the tyre is like less than one millimeter from one side of
the frame. My toy is almost broken :slight_smile:
I was wondering if there is better clearance with the other available
frames (ie the semcycle, monty or pashley) ?
Oli-
opaugamATaptilonDOTcom !
opaugam@aptilon.com (Olivier Paugam) writes:
the clearance is pretty good on Paul Wyganowski’s frames for Monty wheels.
you can check out some pics at:
www.dustinkelm.com/trials
if prototype B isnt up yet it should be soon, i sent pics to my bro a
couple weeks ago. also, the beauty of ordering from Paul… if you really
wanted more side to side clearance, you can specify that with him and he
will make the crown a little wider to accomodate you.
keep on trying, dustin kelm unicycling productions www.dustin.kelm.com
(remove the BICYCLE from the above address to send me your brain waves)
isa 40:29-31
I have a Monty wheel I use on my Telford sometimes. It has lots of room
and feels ultra-light.
David Maxfield Bainbridge Island, WA
