Alright, after extensive searching of the forums and nights upon nights of picture analysis I’ve come to the conclusion I need to start a new thread, asking for help.
I got a Roach seat cover from uni.com a week or so ago and waited with much anticipation to get it on my Miyata saddle(and may I take the time to mention my shipment arrived in 4 days. Note the fact that I live in Canada! I was amazed at the shipping speed. Thanks to the wonderful folks from Marietta!). I tried the bolts, got a friend’s Dremel Tool and let the buggers see the light, so to say. Anyhow, I fiddled with the seat cover, experimenting with the dogbone pillow and the original Miyata foam, unable to fit both in the cover comfortably, at least not when I got around to sticking the saddle base in. I think I may have too much air in the pillow, as John Childs was able to fit this combination in just fine, see this comment:
John, by your description it would seem you have one of the “new” Roach covers (lycra bottom, four little loops, etc. – see all Diagrams). Did you trim your original foam down any, as I’m finding it hard to fit it well. Did you ever run into an issue of the foam not fitting at the top of the cover?
This is really a small matter and I can play with the amount of air and the size of the tube to make things fit. My huge (and currently insurmountable) problem is the fitting of the cover on the seat (hence the title of the thread… imagine that). My problem lies in the positioning of the front two little loops (see Diagram 3) and how they interact with the front bumper/handle. I was able to melt holes in the lycra bottom (Diagram 3, little white holes) for the bolts and was able to secure the seat post and rear bumper with little problem – the front bumper is altogether a different story. I have as of yet been unable to fit the cover on the seat bottom so the front two loops are anywhere near out of the way of where the front bumper needs to go (the bumper won’t fit comfortably on top of the loops). I know it is possible to arrange it so things fit together with ample room to spare (see Diagrams 1 and 2) but for some reason it isn’t evident to me how this is done.
The front loops on my seat cover are as in Diagram 3, pretty much at the front corners of the cover. If I find this method of holding the seat cover on to be insufficient, I will get grommets/eyelets installed, but for now I’d like to get this system working. There was one person who also said they just cut off the lycra and used the original saddle clips. Have there been others who have done this? Has it worked well for you? Do you have any issue with the front loops?
It’s been about 15°C here for the last couple of days and the trails are starting to dry up… I need to get riding. Thanks to anyone who may be able to help.
Later,
Eli.
Diagram 1 (from this post):
Diagram 2 (original image):
Diagram 3:
