I have a file that I want to read that was from kmail in the mandrake
partition of my harddrive. Is there a way for me to read the email on the
windows side?
Where would I find the files that kmail makes?
windows side?
Re: file location in linux
> windows side?
Well you can read it with any text editor.
/home/yourusername/Mail
John R. Marshall - Web Developer
JRM Studios - http://www.jrmstudios.com
The Hotrodding Network - http://www.hotrodding.net
You also have to get a tool to read the Linux partition in Windows. If
you are using ext2, I know there are tools that can read an ext2
partition in Windows but writing is still experimental. I don’t have a
URL but a Google search should find it. If you are using something like
Reiser or XFS then you may be out of luck.
Josh
>>windows side?
“John R. Marshall” <john@jrmstudios.com> wrote in message
news:ai7728$50e$1@www.darklock.com…
Thanks, but I don’t see this directory on the Windows partition? I guess
I’ll need the special tool Josh was talking about?
Yes, windows will not read a linux (ext2) partition, it will simply
ignore it. You’ll need a special program to access the linux partition
from within windows.
-Mike K.
>[color=darkred]
> Rodney Blackwell - site owner/administrator
> http://T-ShirtCountdown.com http://TalkT-Shirts.com/
> http://ihateclowns.com/ http://Globie.com/
> http://DomainJunkies.com/ http://5R5.NET
> http://GotPaintball.com/ http://CircleRPrinting.com
> ------------------------------------------------------------[/color]
Boot into Linux, copy to a floppy, boot back to windows
or boot to linux, forward the email to yourself, boot back to windows, and
check your email.
or format windows and dont worry about it
Or in linux, you can mount the windows partition, copy the file there,
and when you boot back into windows, the file will be accessible to you.
-Mike K.
> check your email.
