Sure, but Up Rite describes himself as “a wall hugging beginner”, and in this situation I wouldn’t recommend to ride in the traffic. I think that getting rid of the unicycle is good beginner tactics. The better you get later on, the better you will be grabbing the uni behind you in an UPD.
The high speed exits I focus on saving myself, pushing off with a big leap into a sprint which both helps me keep upright and get away from the falling uni. I have come off at over 20 kph and I can’t run that fast so it is left hand superman slide after the first step.
Never been seriously hurt from a high speed crash but they have never involved collisions. As they say, it isn’t the speed that is the problem but the sudden stop.
The low speed ones are more often a problem. Falling straight down from a failed takeoff was among the worst. (A very sudden stop.)I didn’t have wrist protection on because I was only on the 20 inch going to work after dropping off my car for a service. Plus I injured a rib. I hurt for weeks.
I have helmet, wrist guards, QUAX elbow, and Kris Holm leg armour. My stamina and recovery ability is better but still very limited for this unicycling activity. So for now I put in as much pre planning and strategy as possible to make my training sessions count. The main thing is that I need to be as fresh and rested as possible before I take on a unicycling practice session. Otherwise I just fall off. In contrast, I can take on weight training, hiking, callisthenics etc. while tired and sore.
I know that as I get leaner and lighter I will be able to train longer and more frequently. I am also certain taht somewhere on the way it will just click and I will be able to ride unassisted in a straight line. Once I get to that point where the ability is internalized it will be much less of an energy drain regarless of my level of conditioning.
After that I will start to work on getting better at other unicycling skills.
Don’t underestimate the benefit of spontaneous training. I actively tried working on riding backwards for ages with little improvement.
I’m still not very good at it, but one day last year all of a sudden I could just do it.
This was on the first day riding after a break of months (I mean a break from unicycling, not just a backwards-riding-break)!
After I was pretty good in a straight line the next biggest fall-avoidance improvement for me was riding with one or both hands on the handle (and then on a handlebar setup).
It forces you to transfer some balance control to your hips and gives you extra leverage for 'surging' the pedals if you need to pedal hard to avoid falling forwards.
Pushing with my full strength on a pedal just unweights the seat unless I'm also pulling hard on the handle.
I'd never tell an absolute beginner to hold the seat before they developed a good arm flailing action though!
I don’t think there’s such a thing as a good arm flailing action. It may be necessary for beginners (and for me while wheel walking), but it seems more like an act of desperation rather than a proper technique.
My neighbor, an athletic teen, learned to ride 30 feet in less than 30 minutes of practice. His technique was consistent; he kept one hand on the seat and flailed with the other arm. He sacrificed the balance of one of his arms flailing for the stability of one hand on the seat. And he learned very fast. Granted, he was learning on a cheap unicycle that didn’t help keep his bottom stable. So, he was compensating for a less than perfect setup.
Mounting, in my experience, is more difficult when the mount starts with both hands in the air. I think it’s easier to start with one or both hands on the seat, then once I establish weight-in-the-seat, one or both hands can be removed for balance. My acquisition of a proper static mount happened when I started placing both hands on the seat during the mount. Mounting without a hand on the seat seems more dangerous to me. A failed mount may cause the unicycle to go shooting out in front or behind.
Hands on the seat is a game changer. I encourage beginners to take whatever baby steps they can toward riding this way. I suggest trying to balance with the elbows pointed out, rather than the hands. That puts the hands closer to the seat.
I suppose you’re right. I certainly didn’t mean elegant flailing! Just being able to ride while making large arm waving corrections was my first step. This is how I teach people. Controlling the desperation and then pursuing the calm, handle holding stance (where most of the balance comes from the hips) came later for me.
I tell beginners that the key is to bias your arms roughly in the middle of their movable range and use this as the neutral position. This way when you expose yourself to the feeling of being unbalanced you have a really good range of motion available and can make large corrections in any direction.
This is why I think holding on to something while learning is counterproductive after about the first ten minutes. I learned to freemount no hands straight into riding.
It’s also a lot easier to help a learner if you can get them to employ the arms because you can see how they react once they start to tip. If they keep falling to the right, telling them to punch an arm out hard to the left instead of just stepping off really starts to join up the synapses! They’ll probably still fall off but now they have felt the effect of a rapid shift in weight and will have learned a new tool to control their CofG.
The next step is calibrating the effect caused by this weight shift:
Once riding, you can see what happens when you move your arms to one side or the other when you don’t need to. A corresponding opposite weight shift is then required at the hips to compensate.
I think this is the bit that was ‘good for the core’. Non-riders always seem to mention this. For me, simply riding is now no better for the core than walking. It all just happens automatically!
I think I’ve gone off-topic here. Back to the original question:
[quote="Up Rite
Is there is anything in the world of falling to be aware of?
Before I could with both hands on the seat and elbows sticking out, I focussed on having my hands on my chest. Once that went ok, I moved them downwards to the seat. I don’t balance so much with my elbows, but more with my hips now. Also handlebars help against flailing, but that shifts the balance point somewhat, which is not something beginners will get into yet.
As for mounting, I always mount with one hand on the seat, but occasionally I mount with both hands in the air and at those moments it seems easier somehow. When holding the seat with my right hand especially on a 36", I tend to hang too much to the left. With both hands in the air, I will automatically be more in the center.
I guess for 30 years, that is pretty good overall. Interesting that most were low speed, and you went for teh safety gear after most of the injuries. So far I always wear Kh leg armour, QUAX elbow protection, and a helmet. When I attempt to get away from the rail/ wall, I wear wrist guards, I find they interfere with grabbing the rail.
After I can ride away from the wall, I will invest in KH gloves. Somwhere along the way, probably when I am leaner I will get some good padded cycling shorts and spine protector.
