My desktop, fonts, icons, and everything are a lot smaller. The went into display to change the screen resolutions but I can’t get it back to normal. Any suggestions?
With the amount of info you supplied, I could give you the steps to try to change your screen resolution in Windows. Are you using Windows?
Did you already try this?
If so, what happened?
How did it change in the first place?
Are you sure it’s a screen resolution thing?
Got spyware or adware (if it’s Windows, assume the answer is effectively yes)?
A similar thing happend to me like that. Everytime i go to any website all the words are alot bigger. I think i hit some hot key that caused it to change.
My first thought would be that your resolution is really high, but if you already tried that to no avail I’d suggest making sure your DPI is at the normal size (96 dpi, right click on desktop -> properties -> settings ->advanced -> check the DPI setting).
does any know how to change my websites back (see above post)?
Assuming you use Internet Explorer go to View -> Text Size -> Medium
With Firefox press Ctrl + +
With Opera just press + on the number pad
IT WORKED!
Re: Everything’s Tiny
Then stop looking down your pants…
Re: Re: Everything’s Tiny
Hog tie me and pull out the branding iron, that was a burn involving serious ownage.
DPI is 96, resolution is high, but anything lower messes with the colors, makes things look low quality. The font has changed and has changed in every program. Firefox, Real Player, the start menu and bar, everything.
It probably is a virus. Stoopid Windows.
hold Ctrl and move the scroll wheel, i think J Pott enlightened me to that one.
It’s a lap top, with no scroll wheel…
Re: Re: Re: Everything’s Tiny
In that case make sure that the Color Quality (next to the resoulation settings) is at 32 bit after you adjust the resolution.
Yep. I am the scrollwheel wizard!
alright losers, you know better than to mess with me. i said J Pott and i meant J Pott
check the dates, mates.
ha, we’re having a SEARCH BUTTON showdown
i started searching cause i was quite sure that klaas bill originally dropped that lil’ gem in here and the JP picked it up from him
i couldn’t find any klaas bill posts with ‘scrollwheel’ in them so i just stuck up the catboy link since that was the only one i could find
scroll wheel
scroll-wheel
scrollwheel
tomato
edit: here’s the thread i was thinking about
JP’s still got it with the dates tho
yes! i am the “wizard” of the search.
Catboy hasnt come in here to take his lashing.
ha what-ever, you sould have posted that much ealier.with a 2 minute + lead here you chime and thread jack.
so easy my friend…so easy.
