Editing Help
Could any one help me make this look better. And take out the triangle.
How does this work? Removed most of the “muck” from the circle area, and did my best to clean up some of the other stuff people with a better program might be able to do. I kept it white as I was not sure which color you wanted.
hey nice avatar. Does madison know about that?
Thats perfect!
Has anyone else gotten anything. Even thought there is a good one out there, good things can be beat.
Telling us what you’d like would be a nice place to start…
I want the seat to just have a lift handle, not a flat spot befor it. And I also want it to be white on a black backround.
Still a bit fuzzy on the sides, but if you just use a quick paint prog and make it small it should eliminate that if it bothers you.
