Echo isis crank bolt
Any idea if these work with kh hubs? I I know that there are two sizes of isis crank bolts, I think kh uses the smaller of the two correct? I think the koxx light uses the larger bolt as it saves some weight, which these are probably the larget version.
Thanks for any help, I’m not 100% on any of this so somebody smart can chime in. They sure would look nice and might save a gram or so haha.
http://webcyclery.com/product.php?productid=18485&cat=415&page=1
I have no clue, BUT they look sick! I want them if they work. :smiley:
You got it, plus the Newer KH hubs all ship with a longer bolt, which you want to make sure you have if you want to use Rollo Disks.
Mail tartybikes.com and ask them if works with a reinforced koxx hub…
I’m pretty sure they have some unis in stock and also those bolts!
Good idea about the mailing. I’ll get to that.
Also nathan, I think it was you who said some of the koxx crank sizes are proper now? I think you said the 140’s were. I’m some what interested in testing them out, but not if they don’t work with a kh hub.
