> ---------- Forwarded message ---------- From: VeriSign Global Registry
> Services Subject: Registry Advisory: Temporary Suspension of Batch
> Delete Process
> To All Registrars:
> VeriSign Global Registry Services (VeriSign GRS), after consultation
with
> ICANN, will temporarily cease batch releases of deleted .com, .net and
.org
> domain names to assure continued service quality within the Shared
> Registration System (SRS). Batch releases are made by the registry
five days
> after deletions by registrars outside of grace periods.
> Why We Are Doing This
> This interim action was prompted by extraordinary loads placed on the
SRS
> arising from several registrars attempting to register newly released
domain
> names through abusive use of the SRS. In recent weeks abuse of the
system by
> a few registrars has escalated to the point where other registrars
have been
> seriously impacted in their ability to transact normal business
activity.
> The abuse has been characterized by:
> It is important to note that the current number of connections and
bandwidth
> is sufficient to satisfy all reasonable attempts to conduct normal
> registration business, both now and in the foreseeable future. As an
> example, the registry is easily capable of sustaining 6x growth in our
> database transactions over the typical peak workload rates even
without
> adding additional hardware. Further, until the most recent increase
in
> demand for connections, the registry consistently had a pool of
available
> connections that was twice the size of anticipated demand.
> <end forward
so that means they won’t delete at all? when does this start. I just
grabbed 2 deleted domains last night.
Rodney Blackwell - site owner/administrator
http://T-ShirtCountdown.com http://TalkT-Shirts.com/
http://ihateclowns.com/ http://NewT-Shirts.com/ http://DomainJunkies.com/
http://EmailSources.com/ http://SellYourLogo.com/ http://JackAssMail.com
Free Color Business Cards http://www.linkcounter.com/go.php?linkid=153264
“Winston D. Neutel” <winston@dramaturgy.net> wrote in message
news:9l3qnl$a9e$1@constitution.worldwebserver.com…
> > Delete Process
> > To All Registrars:
> with
> .org
> five days
> SRS
> domain
> system by
> have been
> activity.
> bandwidth
> without
> in
> available
> > <end forward>
Effective immediately no com/net/org are being dropped by the registry
until further notice.
The full text is at http://www.icann.org/announcements/icann-pr10aug01.htm
Here is the description of the offending behaviour
- More than 400 million check commands within a six-hour window to
register a few hundred desirable names each morning - Single registrars executing as many as 1500 attempts per second
- The same registrar sending a check command for the same name in excess
of 1000 times per minute over extended periods of time - Registrars hoarding connections (grabbing all connections up to their
limit) and, with the exception of the describe command, executing
single-digit numbers of transactions until they are prepared to
execute pre-staged batch jobs that will invade the system at rates
noted in excess of 100,000 per minute - Registrars executing in excess of 100,000 check commands for each name
successfully registered, compared to a typical ratio of well under 1,000
check commands for each name successfully registered - Registrars who typically use less than 10 connections throughout the
day, then increase that connection count to a triple-digit number - Registrars who clearly execute an automated check process (i.e., checks
for the same names at rates in excess of 1000 per minute) - Registrars whose typical usage patterns suggest the need for a
single-digit number of connections, and who then increase their
connection count by up to 200 times without a corresponding increase in
productive activity (i.e., a registrar who hoards connections in an
apparent attempt to deny others)
somebody is still releasing domain names. Here are 2 that were deleted on
8/12:
internetcustom.com jdscustomrods.com
> > Delete Process
> > To All Registrars:
> with
> .org
> five days
> SRS
> domain
> system by
> have been
> activity.
> bandwidth
> without
> in
> available
> > <end forward>
People on the OpenSRS list have noticed some of these too. Speculation is
that these were “left over” deletes set to go before the ban that didn’t
happen until after the ban
Rodney Blackwell <circle-r@pacbell.net> wrote in message
news:9la5tl$rmb$1@constitution.worldwebserver.com…
on
> 8/12:
> http://DomainJunkies.com/ http://EmailSources.com/
> > > Registry Services Subject: Registry Advisory: Temporary Suspension
> > > of Batch Delete Process
> > > To All Registrars:
consultation
> > with
and
> > .org
> > five days
the
> > SRS
released
> > domain
> > system by
> > have been
> > activity.
> > bandwidth
an
our
> > without
increase
> > in
> > available
> > > <end forward>
