I’m mediocre at hopping, but I am trying to get better. Most of the hopping that I have been doing is trying to stay in one place standing up. Not “pogo stick” hopping, but just trying to remain still. I can’t really get much altitude and I am terrified of rolling down curbs.
I figured that if I built a short box, say 60% of the height of a sidewalk curb, that I could practice somewhere and work up to going up and down curbs. I can jump up on a platform that is about 30% of a curb height pretty readily. I made it out of a piece of scrap plywood and some scrap wood as spacers on the bottom. It is about 2 foot square (60 cm square).
What sorts of platforms do you guys use / have made?
I also made an “obstacle” out of a round post that I fixed to some dimensional lumber to keep it from rolling around on me, but it is beyond my skill level right now to ride over it.
I think there is a clear difference between hopping up a kerb and rolling off it. With some disciplinary push, I can get my self to ride off a kerb, even if it initially comes with “Im scared, Im gonna hop off”. After the first time riding off, a lot of that fear will drop away and you can do it again.
As for hopping on a kerb, I might have only done this once or twice, but I envision myself not hopping high enough and then tripping over the side of the kerb (would also wouldn’t be good for the rim.
It is good of you to focus on controlled hopping rather than pogo-hopping. Hopping gets tiring pretty quickly. But I’ve noticed also there, it is one thing to make a hop and stay put and another to direct your hops to a certain point.
Lastly riding over a round pole, even if it is stuck to the ground and doesn’t roll away, is not easy. It requires more of a rolling hop. Some of the speed bumps in NL look like that. I tend to ride around or just get of the uni to just walk over. Free-mounting doesn’t take any time anymore. For many bumps on the road it is sufficient to just stand on the pedals (rather than sitting on the seat) and only maybe jump a few cm to get over them, to get the clearance required. Still a round post is higher than such general obstacles.
So I’d say if you can identify the different techniques required here, you can just focus on one at a time. Good luck and have fun.
Rolling down a curb seems a rather natural thing to me (as opposed to rolling down obstacles that are higher). To practise I would look at curbs (or substitutions) with growing heights up to the height of a typical curb in your neighborhood.
Same procedure for riding up a curb. This takes considerably more determination in my experience, and also more skill. You can‘t just ride and then correct for the impact as you can do with small imperfections of the tarmac. You have to anticipate the impact. By grabbing the seat (or bar) you increase your ability to put lots of force on the pedal. This you can use to kick the uni forward just before the moment of impact and/or to keep moving when riding up the obstacle. Also, the position of the pedals is important. With a bit of practising time you learn how much of an extra curve you have to take so that the pedals will be in the perfect position when the wheel hits the curb. Also, it could be helpful to ride towards the curb at an angle, say 45degrees, and then turn in to 90degrees when the pedal position will be optimal. Hard to describe, but when practising you‘ll quickly feel what I mean.
Edit: Just stumbled upon this video of George Peck in the „videos that inspire you“ thread. It‘s insane what he could achieve without grabbing the seat! Even riding up a big curb - that‘s about double of what I consider a typical curb. I once or twice managed to ride up such a curb …on my Oregon with a 4“ wide tyre and very low air pressure. He‘s riding some uni with an ordinarily dimensioned tyre, there!
My first hopping platform I made is attached, along with a ramp I made for it. Raising the platform is really easy, by just adding another 2x4 (or 2x6) layer. I added my Trials uni for size context. It’s not perfect, as I used scrap wood I had laying around. Somehow, I had a perfect square of 3/4” plywood
Thanks for the pictures. Those help.
I had made a platform that was 4" high, and couldn’t roll up on it and I was thinking it was just me being new to it, but I gather that rolling up a 4" step is kind of nontrivial - I’d have to time a hop right, perhaps also with correct pedal alignment. I just couldn’t get it right.
I’m going to make a 3" one next … I figure that somewhere between the 2" that I can do and the 4" I can’t do is the right height to practice …
Try to not to ride towards the curb frontally, but at an angle. Shown here by George Peck. So you can turn and tackle it (frontally) at the perfect moment as far as pedal position.
Also, wearing protective stuff helps psychologically, I find. It allows me to commit and send it more easily than if I’m not wearing any.
Just saw that video by George Peck. Very impressive the way he takes a road uni to do municycle-skill riding. Super controlled. And he is so conservative about it that other dedicated riders can do it much better. And yes like he also says, once you get into unicycling you’re basically hooked. It becomes very addicting and there are tons of different things you can do with unicycles. Thanks @Wheelou for sharing it.
Absolutely. He rides completely different, which is probably largely due to the road uni he uses. Instead of plowing through like most people on today’s unis would he makes a half rev, stops, then another half rev etc. For this riding style you have to have a very good balance while standing (nearly) still, which I find way more difficult than keeping the balance while moving.
Also hopping is harder with such a slim tyre and the higher air pressure it requires compared to a fatter tyre.
Agree completely. A lot of my friends and acquaintances just look at me like I’m strange when I tell them about unicycling. They don’t know how fun it is!
Many people don’t understand, because it isn’t mainstream. But that won’t stop me from riding anyways. Though I prefer to ride where there are fewer people, so not in town.
I recently got laughed at by a bunch of kids, presumably first or second graders. That’s an age where they usually react with admiration rather than derogativeness.
I guess it’s mostly a question of education - do you teach your children to look at new or unusual thing with curiosity and positiveness or do you teach them to react by putting “different” people down.
