DIY Camera Crane Tutorial
Here is a tutorial for the camera crane I used to film this video:
It’s simple, cheap and produces very good results.
Great tutorial! Making the camera crane looks simple and cheap.
Maybe I’ll try it. Thanks for the video :smiley:
I have a question: did you buy the sheet L brackets or did you build them? Because I really want to build this camera crane but I would buy the L brackets cause I’m not familiar with weldings and my parents aren’t too
Thank you!
I built the L brackets. Even if you can’t weld you could still bend sheet metal and use rivets or bolts to hold it together. I’m sure you could find a way to make the brackets out of wood too. Everyone has different materials and tools available so most people will build it their own way using what they have. As long as it performs the same function you can make it any way you want. Good luck!
