I’ve been a forum member many years although I post less often than previously.
Recently, the appearance of the forum changed on my screen, and now every time I try to post, it shows the message “working” for ages, then times out. It takes several attempts to get a reply to post, and then sometimes I find it has posted 2 or 3 times. Even deleting the duplicates takes 2 or 3 attempts.
I’ve not experienced similar problems with any of the many other activity forums I participate in.
Has anyone else had this problem? Does anyone know the solution?
My doctor recommended I drink at least six glasses of water a day, a diet high in fiber, and to avoid red meats. Since then I’ve been able to post comfortably, regularly, and with greater enthusiasm!
I know the covid made all of us paranoid of surfaces, but the envelope with the stamp still goes in the blue box and even with mittens you should manage to grab the handle and swivel it open ;o)
Instead of just hammering it into the ground, try to dig a small hole before (using water if the ground is too compact) and you will have it in place in no time (and less vibrations into your skeleton from the repeated impacts) :o))
