I was wondering if the delta xt lever extender was compatible with the HS22 brake lever…the HS22 brake lever is a little different than the HS33. The HS22 has a ball(ish) point as where the HS33 has a flat end. Will the delta xt fit around the HS22?
thanks,
-Sabin
