cranks
Any special tools or tricks needed for changing cranks on my N36? Sorry if this posted twice, I didn’t see my first one.
Thanks,
Marty
You need 14mm socket wrench to remove the bolt and to re-install the crank and a crank puller (like this one) for removing the cranks once the nuts are off. You will also need a 13mm wrench for removing and replacing your petals.
the park tool crank puller and the UDC combination tool make a good pair.
